What's the biggest thing you have moved with a BX
   / What's the biggest thing you have moved with a BX #1
Jimbrown
Tombstone Az
KIOTI LK30
What\'s the biggest thing you have moved with a BX
Here is a pic of BX with a 5ft tall 24 foot long corral panel on the bucket. I am moving 20 of these about 1/2 mile. already moved 10. I also drug a 8X12 premade shed the 1/2 mile but did not get any pics of that.
   / What's the biggest thing you have moved with a BX #2
Re: What\'s the biggest thing you have moved with a BX
Last weekend I had to move my 32ft camper to its permanent location. It weighs about 6000 lbs. I loaded up the bucket with rock before attempting to lift it with the three pt. trailer attachement. I had no problem at all either raising it with the 3pt or pulling it around with the tractor.
I did need a lot of help from my wife to yell WHOA WHOA WHOA when I was about to hit something. I reall could've used 10ft wide mirrors. /forums/images/graemlins/wink.gif
   / What's the biggest thing you have moved with a BX #3
Here is another pic from the front with the loaded bucket.
   / What's the biggest thing you have moved with a BX #4
So Hacker,
What kinda highway speeds do you get with that tow vehicle?
Ron
   / What's the biggest thing you have moved with a BX #5
I thought the manual said the load rating for the 3pt is 1950#. I've not pulled my camper or boat around because they come in at 3500# and didn't want to break the 3pt.
Am I reading this wrong in the manual?? /forums/images/graemlins/confused.gif
   / What's the biggest thing you have moved with a BX #6
Bob, your camper and boat surely don't have 3500# of tongue weight, do they? And that's what the lift capacity of the 3-point hitch is talking about. Of course when the manual talks about trailer pulling weight, they have to factor in stopping ability as well as pulling ability.
   / What's the biggest thing you have moved with a BX #7
<font color="blue"> I thought the manual said the load rating for the 3pt is 1950#. </font>
For the BX2200 - at the lift point - 1210 lbs.
----------- 24" behind the lift point - 680 lbs.
Don
   / What's the biggest thing you have moved with a BX #8
No Bird I meant just weight of the trailer. The tongue is 200-300# but pulling it was what I was worried about. It seemed in the book that the load weight was limited to 1950#.
Obviously the tractor can do 6000# with little effort by the looks of it in the picture but it's level hard ground. I park my camper out back and move it with the half ton truck. I would like to get a 3pt hitch and use that if I can but should I limit it to things under 1950#??
   / What's the biggest thing you have moved with a BX #9
</font><font color="blue" class="small">( should I limit it to things under 1950#?? )</font>
Bob, I'm sure not going to tell you to ignore what the manual says /forums/images/graemlins/wink.gif 'cause if you have an accident, I don't want it to be my fault, just as Kubota doesn't want the responsibility. /forums/images/graemlins/laugh.gif But for me, personally, I didn't worry about the pulling weight limit my Kubota manual listed. As far as pulling was concerned, I figured if it was too heavy, I'd either spin the wheels or I'd notice the engine straining and I'd back off then and I certainly was not going to damage the tractor. However, I did always consider the terrain, any slopes, momentum, etc. as to whether or not I could safely stop whatever I was pulling.
   / What's the biggest thing you have moved with a BX #10
The wife moved out of my way one time does that count? /forums/images/graemlins/grin.gif
for real I mose a camper like shown all the time on flat land. Just have to be careful not to stop to fast
2004 FREIGHTLINER COLUMBIA (A53843)
2004 FREIGHTLINER...
2015 Chevrolet Silverado 2500 HD Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
24FT Enclosed Trailer (A53424)
24FT Enclosed...
JOHN DEERE 6135RW401 MOTOR (A51247)
JOHN DEERE...
2009 MULTIQUIP 25KW GENERATOR (A53843)
2009 MULTIQUIP...
2012 PROCO 130BBL VACUUM TRAILER (A53843)
2012 PROCO 130BBL...
