whats the best way to open/inspect a oil filter?
   / whats the best way to open/inspect a oil filter? #1
BWS
seattle area
kubota l3830 hst/723 fel
i have a band saw but that would add shavings.what do the pro's do??
   / whats the best way to open/inspect a oil filter? #2
There is a proper cutter for that application I believe it is a chain type.If you really want one after market auto supply should be able to get you one.
   / whats the best way to open/inspect a oil filter? #3
Ditto u can get them at most HD engine makers like cummins, cat detroit etc..
   / whats the best way to open/inspect a oil filter? #4
When I worked at a Freightliner dealer , I would use an air chisel with a panel cutting tip. Peels it open like a can opener. Cut the paper open with a razor blade. I would burn some of the oil and if it "crackled" , it ment it had water/antifreeze in it.
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
2013 Dodge Charger Sedan (A52377)
2013 Dodge Charger...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
1065 (A53342)
1065 (A53342)
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
Utility Trailer (A52377)
Utility Trailer...
