whats the best way to open/inspect a oil filter?
   / whats the best way to open/inspect a oil filter? #1
BWS
seattle area
kubota l3830 hst/723 fel
i have a band saw but that would add shavings.what do the pro's do??
   / whats the best way to open/inspect a oil filter? #2
There is a proper cutter for that application I believe it is a chain type.If you really want one after market auto supply should be able to get you one.
   / whats the best way to open/inspect a oil filter? #3
Ditto u can get them at most HD engine makers like cummins, cat detroit etc..
   / whats the best way to open/inspect a oil filter? #4
When I worked at a Freightliner dealer , I would use an air chisel with a panel cutting tip. Peels it open like a can opener. Cut the paper open with a razor blade. I would burn some of the oil and if it "crackled" , it ment it had water/antifreeze in it.
2018 Freightliner M2 106 Altec LR756 Forestry Bucket Truck (A52377)
2018 Freightliner...
2015 ISUZU NPR 16FT BOX TRUCK (A54313)
2015 ISUZU NPR...
2006 International 7400 Dump Truck (A47477)
2006 International...
2005 Nissan Titan (A50121)
2005 Nissan Titan...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A55218)
2016 RAM 5500...
2007 Ford Expedition EL Limited 4x4 SUV (A53424)
2007 Ford...
