What's the best way to clean an 06' RTV?
   / What's the best way to clean an 06' RTV? #1
inseeme
Stoneville, NC
Kubota M7040
What\'s the best way to clean an 06\' RTV?
I have a troy bilt pressure washer and my rtv has 15 hous on it and needed a bath badly! How doe everyone else wash there machine I used the easiest tip and washed the whole maching with the pressure washer It looks brand new again! Just do not want to damage anything? How are other owners cleaning there machines?
   / What's the best way to clean an 06' RTV? #2
Re: What\'s the best way to clean an 06\' RTV?
i got a pressure washer for my gator . there ain't no way i can get don there an scrub her my self. she sees alot of mudd duty.
   / What's the best way to clean an 06' RTV? #3
I wouldn't use a pressure washer, but only a hose and a brush. Too many places water can penetrate where it shouldn't be, IMO. But you do as you like.
   / What's the best way to clean an 06' RTV? #4
I've my RTV for a year and a half.
I have pressured washed it a half dozen time with no problems. I use a lower pressure nozzle - 500 or 1000 PSI and just try and be careful where I spray.
If you have a bed liner, there is almost no other way to get the mud off.
   / What's the best way to clean an 06' RTV? #5
I've always used a pressure washer and have had no issues.
When done, just let it air out for awhile before starting.
The rubber mat in the passenger compartment will collect water under it. I try to flip it up a bit (from the front) to let that area dry.
   / What's the best way to clean an 06' RTV? #6
if things are not stuck too hard a leaf blower can work really well.
Thanks for all the posts, I really appreciate the feed back.
   / What's the best way to clean an 06' RTV? #8
I use a pressure washer to wash everything I own that moves, and then some things that don't move too. I stay away from delicate areas, or areas that have electronics.
It saves time and effort on the tractors, RTV and vehicles, for sure.
This summer the buildings will get their due.....
-Mike Z. /forums/images/graemlins/grin.gif
   / What's the best way to clean an 06' RTV? #9
I just hose mine down with my garden hose whenever it needs a bath.
UNUSED JCT HYD AUGER (A57193)
UNUSED JCT HYD...
2018 Hyundia Robex 35 (A53317)
2018 Hyundia Robex...
UNUSED WOLVERINE SG-13-08D HYD STUMP GRINDER (A57193)
UNUSED WOLVERINE...
2015 CATERPILLAR 272D2 SKID STEER (A52707)
2015 CATERPILLAR...
2014 Chrysler 300 S Sedan (A55853)
2014 Chrysler 300...
2016 Ford F-450 Flatbed Utility Service Truck (A56858)
2016 Ford F-450...
