Tiller What's the best PTO rotary tiller?
   / What's the best PTO rotary tiller? #1
two-socks
Florence, Texas
Kubota M6040
I'm looking for a new 72" PTO rotary tiller. Tractor Supply has a new CountryLine brand but I'm a little leary of new models. I've heard that Maschio equipment is one of the best but they don't seem to want to call me back. Can any of y'all give some good recommendations? Thanks,
Jon
Florence, Texas
   / What's the best PTO rotary tiller? #2
I won't comment on what the "best" rotary tiller is as I am sure that would open up the 55 gallon drum of comments, but I have a Land Pride RTA3576. I have only used it for this planting season. It appears to be a good heavy unit and works well in both the old clay and in turning over new sod (you will have to go over it several times). I probably put 10-15 hours on it with no issues. I hit some pretty nice rocks turning over the new sod, but it just kept on going.
   / What's the best PTO rotary tiller? #3
Countryline tillers are King Kutter tillers with different decals. Period. Same assembly line, same parts. They even have King Kutter serial numbers. Call King Kutter customer service if you need further proof.
The King Kutter tillers are well respected values. You can spend a lot more on a tiller and it might be worthwhile if you are a commercial farmer but for most uses the standard King Kutter tillers work just fine.
   / What's the best PTO rotary tiller? #4
I have a LandPride tiller and love it. Is it the best? I don't know, but I do know that LandPride will ALWAYS be my first option when it comes to implements. I have one of their 48 inch core aerators on order right now. LandPride is definitely not cheap but it is VERY well made and it's "made right here in America". With all of that said, I have yet to meet an owner of KingKutter equipment that didn't feel they got their moneys worth. Good luck and let us know what you get and how you like it! :p
Troy
   / What's the best PTO rotary tiller? #5
I have woods. I don't know which is best, but it isn't woods. Their equipment is usually great, but this is rebadged italian junk at woods prices.
From what people say on here, I wish I'd known about the king kutter.
   / What's the best PTO rotary tiller? #6
Another vote for Land Pride here. I have a buddy that has one, not sure of the exact size though. Anyway, that thing is built very well and built right here in the USA. He's had no problems that I know of and it does a great job.
   / What's the best PTO rotary tiller? #7
I've owned a KKII 72" tiller for 4 years. This year, I not only did my garden, but I also tilled several areas of native soil where I wanted to take 6" of topsoil off with my FEL. Even though I hit several football-sized rocks, the tiller did fine with no signs of any damage. If the Countyline stuff is KK rebadged, then I think you will have no problem with it.
Whatever tiller you buy, be sure the gearboxes are filled with the recommended oil, the tiller is greased, and the slip clutch adjusted before first use. These things are not done by the dealers. The gearboxes are shipped dry.
After first use, go around the tiller and check fasteners. All of them are subject to a lot of vibration and bolts loosening with use. My gearbox cover needed tightening on my KKII. I notice a small seep and took care of it before it got to be a problem.
   / What's the best PTO rotary tiller? #8
I try to get just about anything I buy at a place that gives good service on their product or the products they represent. Distance to get anything serviced is another consideration. I live a ways out and hate driving any more than I have to.
Most dealers can get a good variety of tillers and other attachments. I bought a Land Pride from a reputable dealer because I feel it was the beefiest tiller I looked at and it's made in the USA with a 5 year warranty on the transmission. Yeah, it cost a little more but it fit my needs.
Paul
   / What's the best PTO rotary tiller? #9
In June I bought a CCM SR 185. I have not had the time to use it yet but I can tell you it is HEAVY DUTY. It weighs 1100 pounds, 300 hundred more than the other heavy duty tillers I looked at and it shows! I cannot say if it is the best, but I shopped and did a lot of research and feel it was the best for the price.
   / What's the best PTO rotary tiller? #10
If I had to spend MY money it would go to CCM or the KK II units. CCM will give you better custmer support. bjr
   / What's the best PTO rotary tiller? #11
Have had a King Kutter II 72" for 4-5 years now. I like the fact that it is gear drive not chain - I think that design is sturdier. Also has slip clutch not shear bolt - another plus.
When I first got it I vibrated a couple bolts out of the drive case (there's about a dozen or so holding the cover on). Found them and put them back in and it happened again. Drained the case, got rid of their crappy gasket and replaced with a good bead of RTV seal then put locktite on the bolts and added locking washers for good measure. I did this about 2 weeks after I got it and it hasn't had any issues like that ever again. Something to keep an eye on.....probably on any model you buy
Just this year I cracked/blew out one yoke on the pto shaft and snapped a lower arm pin on it....hey, I'm tough on equipment. I also had to do a set of friction disks in the PTO shaft while I had it apart since they were pretty worn down
Overall it's definitely money well spent
   / What's the best PTO rotary tiller? #12
I recently rented a Bush Hog brand 72" tiller and was not impressed. It bounced over the ground and shook the tractor like a vibrating lounge. Granted it was a rental unit and the tines were pretty worn, but it was a chore to use.
I recently bought a King Kutter 72" unit and it is night and day above the Bush Hog unit. It's quiet, doesn't vibrate and cuts the ground much faster. Plus I found it on EBay for $1200.00 from a dealer not too far from home.:)
   / What's the best PTO rotary tiller? #13
NO comment on which might be best since I have only ever used the Landpride tiller I have now. I bought it used, and by appearances it was well used, all I did to it was put on new tines and a new seal on the chain case. Since then I have used it for cutting sod, tilling gardens and breaking ground so I could scoop it up with the FEL. No issues at all. Good solid unit.
   / What's the best PTO rotary tiller? #14
I dont own one myself, but have used a friends landpride. Like most landpride equipment, it was built like a tank and worked well.
   / What's the best PTO rotary tiller? #15
I have a 81" Buhler. Did about 4 acres with it, twice. No problems in rocky soil.
It is heavy, about 900lb, goes about 6-8" down.
   / What's the best PTO rotary tiller? #16
Don't buy a bulldozer unless you really really need it and then lease it instead.
Never buy a dump truck period. Take a nice vacation and clear your head instead.:D
Steve
2016 CATERPILLAR D5K2 XL CRAWLER DOZER (A60429)
2016 CATERPILLAR...
2014 CATERPILLAR 930K WHEEL LOADER (A60429)
2014 CATERPILLAR...
2004 VE ENTERPRISES 500BBL FRAC TANK (A58214)
2004 VE...
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
KBH Water Trailer BNT-1 (A61306)
KBH Water Trailer...
2015 VOLVO L110H WHEEL LOADER (A60429)
2015 VOLVO L110H...
