What's the best attachments?
/ What's the best attachments? #1
chuckkessler
What\'s the best attachments?
I just bought a used 1925 33hp NH and am looking for information about what attachments I should buy. Some other NH owners said to buy NH fel, a Woods backhoe and a Bush Hog post hole digger. Are they correct?
Chuck
/ What's the best attachments? #2
Re: What\'s the best attachments?
chuckkessler,
Welcome to the board and do jump right in w/both feet. /w3tcompact/icons/wink.gif
The FEL the most helpful attachment I consider,and it will more than pay for itself in years to come.
Thomas..NH /w3tcompact/icons/wink.gif
/ What's the best attachments? #3
that depends...
chuck,
you have to tell us what you want to do with your tractor, there are thousands of attachments, each will do a specific job well, so you need to assess your property, which tasks that you need to accomplish the most, which tasks you dont need to do at all.
for example i do two major tasks with my tractor, i cut grass and i move material, so i have a finish mower and a rotary cutter, i have a front end loader and a rear blade for moving material (snow, gravel, bark mulch etc...) these two tasks are about 90 percent of what i do with the tractor. my wife likes to landscape the property so a few years ago i bought a post hole digger with a 12" auger, plants trees, shrubs, rose bushes faster than the devil. that is about 2 percent of what i use the tractor for. i have a 3 pt lift to move things around the property, i have a pto generator if the power goes out. i have a tiller to make garden beds. i have a water pump i made into a sprayer.
of the last four attachments, their use comprise the last 8 percent of what i use the tractor for. could i do without them? sure, would i want to? absolutely not. have i bought my last attachment? are you kidding!!!
given my list i would rate the loader as the most usefull. but i use the mowers the most. in your situation it may be completely different.
let us know what you plan on doing with the tractor, i am sure someone on this site has done it before and would give you valuable insight into the proper attachment and its use.
alex
Re: that depends...
We recently bought 14 acres and want to try our hand at growing a garden and orchard. Our first project will be a 32x64 pole barn. We are also going to plant 2200 white pine trees purchased through a state program and started in a state nursery. We bought a used 1925 33hp NH Boomer to help us get the work done. It should be fun.
Chuck
/ What's the best attachments? #5
Re: that depends...
Chuck,
Sound like you have a plan and one busy year ahead for you and your wife.
Boy I wish grow some white pines 25 years ago.
Wish you the best of luck.
/ What's the best attachments? #6
Re: that depends...
I'd have to agree with going with the FEL. I have a NH1720 that I use. I purchased a RZ-60 Bush Hog rotary cutter a little later on and really love it. You think people come out of the woodwork when you have a tractor!!!! You ought to see them when they see a rotary cutter on back of your tractor.!!!! I also purchased a 6 ft. rear blade for snow removel. I like that too!!!!/w3tcompact/icons/smile.gif I thought when I planted a 100 trees a year that I was doing well! 2200 trees /w3tcompact/icons/shocked.gif It will be a busy summer!! Also remember row spacing if your going to mow between them. With a rotary cutter on the back your turn radius increases. Take it from experiance.
Have a great day!!
Al
Oops!!!! Wrong person. Right board!!!!! no coffee yet!
/ What's the best attachments? #7
Chuck
My vote is for a FEL. It's like have a giant, powerful 3rd hand. *G*
Chuck in IN
(2) 60 GAL POLY SIDE MOUNT TANKS (A63291)
(2) 60 GAL POLY...
2006 FREIGHTLINER COLUMBIA T/A 6X4 DAYCAB TRACTOR TRUCK (A59912)
2006 FREIGHTLINER...
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2016 Freightliner...
Crary Air Reel Cables (A63117)
Crary Air Reel...
Caterpillar 120G/130G Motor Grader Parts and Service Manuals (A63117)
Caterpillar...
H&H 500 GALLON DBL AXLE SPRAYER (A63291)
H&H 500 GALLON DBL...
