What's the benefit of more HP on the same frame?
   / What's the benefit of more HP on the same frame? #1
rlee6
Central Florida
Allmand 8435 HST (TYM T330 HST)
What\'s the benefit of more HP on the same frame?
I read a thread on 2310/2810/3510 (all HST's) getting the same loader. Explanation was they are the same frame and the same gpm, so the same lifting capacity. If 3510 (more expensive) has no advantage over 2310 in lifting, when is more HP beneficial? In pulling?
   / What's the benefit of more HP on the same frame? #2
Re: What\'s the benefit of more HP on the same frame?
For operating PTO powered implements!!!
The higher HP tractor will also feel less sluggish, especially under load and on hills.
   / What's the benefit of more HP on the same frame? #3
Since these are nice heavy tractors, the extra power is handy for everything, except it doesn't produce more hydraulic power, so lift capacity will remain the same. The 3510HST is a well balanced tractor. The 2310HST is underpowered, the 2810HST does fine. They have all been replaced by the 15 series built in Japan by Mitsubishi. The 2815 and 3215 models lift over 1400 lbs in the bucket, turn on a dime, and are extremely responsive.
   / What's the benefit of more HP on the same frame? #4
Unless I'm sorely mistaken the 3510 frame is the same as the 4110 and the 2310 and 2810 were the same size. Apples and oranges.....BobG in VA
The thread was about HST's. I should have spelled out 2310 HST, 2810 HST, and 3510 HST. Sorry about the confusion.
   / What's the benefit of more HP on the same frame? #6
Bob,
You are correct if you are talking about the non-HST models, but on the HST's, the 2310, 2810 and 3510 share the same frame. Essentially, the 3510HST and the 3510 shuttle are completely different tractors.
2006 CATERPILLAR 320CL EXCAVATOR (A51242)
2006 CATERPILLAR...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
2014 Brent 1596T Dual Auger Grain Cart (A50657)
2014 Brent 1596T...
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
2021 JCB 1CXT Skidloader/Backhoe (RIDE AND DRIVE) (LIKE NEW) (A50774)
2021 JCB 1CXT...
2015 CATERPILLAR D6K2 XL CRAWLER DOZER (A51242)
2015 CATERPILLAR...
