whats that?
   / whats that? #1
jray
CS Colorado
Shibaura 4x4 SD1840
Okay I have a Shibura sd1840 at all four wheel hubs there are what appears to be a fill cap and a drain plug. What are these things, what goes in there. I haven't checked them since I've had the tractor.
Jray /forums/images/graemlins/confused.gif
   / whats that? #2
There are large bearings in there and you want to put oil in.
   / whats that? #3
How long have you had this unit? Did you travel at top speeds? Sounds like your hubs are oil bathed and the oil levels should be checked. Have you noticed any leaks? If not you should be okay. If you have any leaks the bearing could be running dry....
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
BESTWAY AG VSK50 LOT IDENTIFIER 95 (A53084)
BESTWAY AG VSK50...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A53472)
2023 New Holland...
UNUSED JCT 84" HYD GRAPPLE BUCKET (A51248)
UNUSED JCT 84" HYD...
