What's missing on a JD 5101E to make it cost so much less?
   / What's missing on a JD 5101E to make it cost so much less? #1
Baranx4
Northeastern, Pa.
I was at the local JD dealer last week and saw the sticker on a 5101E @ $42,000 without a loader. That's cheaper than most other brands cab models in a similar size. Is it an outsourced model or is it missing most JD features and basically just a stripped down model?
   / What's missing on a JD 5101E to make it cost so much less? #2
Have you listened to one run in comparison to other engines built today? I don't mean twenty years ago plus years ago! The list goes on from there.
   / What's missing on a JD 5101E to make it cost so much less? #3
Art, can you be a little more specific? I'm interested in this also.
   / What's missing on a JD 5101E to make it cost so much less? #4
i think that it is just a bsic striped down tractor that should be replased:D
   / What's missing on a JD 5101E to make it cost so much less? #5
There are 2 different 5000 series cab tractors, the E Limited and M series. M series will be the high spec units with multiple trans options, but similar powerplants (the 4.5L engine is not a new powerplant to Deere). The E series are the value specced tractors but still have high end features like wet clutch and open center pressure compensated hyd. but only offered with the 12x12 trans. E series also are a cab only option, 4wd only option. Where the M series can be open station and 2wd so there are more choices when speccing out a M series. Check out both versions as much as possible and drive them both if you can.
2011 GMC Acadia SLE SUV (A50324)
2011 GMC Acadia...
2005 JOHN DEERE 5205 TRACTOR (A51222)
2005 JOHN DEERE...
MCELROY COOL PACK 20 (A50854)
MCELROY COOL PACK...
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
71066 (A49346)
71066 (A49346)
2006 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2006 Toyota Tundra...
