What's missing on a JD 5101E to make it cost so much less?
   / What's missing on a JD 5101E to make it cost so much less? #1
Baranx4
Gold Member
Northeastern, Pa.
I was at the local JD dealer last week and saw the sticker on a 5101E @ $42,000 without a loader. That's cheaper than most other brands cab models in a similar size. Is it an outsourced model or is it missing most JD features and basically just a stripped down model?
   / What's missing on a JD 5101E to make it cost so much less? #2
Have you listened to one run in comparison to other engines built today? I don't mean twenty years ago plus years ago! The list goes on from there.
   / What's missing on a JD 5101E to make it cost so much less? #3
Art, can you be a little more specific? I'm interested in this also.
   / What's missing on a JD 5101E to make it cost so much less? #4
i think that it is just a bsic striped down tractor that should be replased:D
   / What's missing on a JD 5101E to make it cost so much less? #5
There are 2 different 5000 series cab tractors, the E Limited and M series. M series will be the high spec units with multiple trans options, but similar powerplants (the 4.5L engine is not a new powerplant to Deere). The E series are the value specced tractors but still have high end features like wet clutch and open center pressure compensated hyd. but only offered with the 12x12 trans. E series also are a cab only option, 4wd only option. Where the M series can be open station and 2wd so there are more choices when speccing out a M series. Check out both versions as much as possible and drive them both if you can.
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A51039)
2012 Freightliner...
JOHN DEERE 450H CRAWLER DOZER (A51406)
JOHN DEERE 450H...
71050 (A49346)
71050 (A49346)
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A51039)
Mitsubishi FG35...
