What's m'diesel saying when he covers me w/soot?
   / What's m'diesel saying when he covers me w/soot? #1
MikeOConnor
Western Wisconsin
Two Power-Trac 1850s (preferred for mowing and grapple-bucket clearing type work on really steep hills). Kubota M680 for snowblowing, grading, bucket.
What\'s m\'diesel saying when he covers me w/soot?
Hi gang,
sheesh, i just looked and it's been *months* since i checked in. my bad. it's been a great summer, filled with all sorts of great PT projects. i've got about a million posts to catch up on.
here's the question of the day. last couple of times i've been out on the PT 1850 i've come back covered with soot.
i Googled "diesel" and "soot" and came up with the notion that the air/fuel mixture was off -- too rich, not enough air.
hmm... air cleaner plugged? went and checked. YES!! Wow!! sooper plugged with the dreaded LFS's (little fluffy seeds) and dust. cleaned all that stuff out and did a little mowing this AM.
it SEEMS better, but i may just be kidding myself. can y'all think of other things the Deutz is trying to tell me when he throws off all that soot?
   / What's m'diesel saying when he covers me w/soot? #2
Re: What\'s m\'diesel saying when he covers me w/soot?
Might take awhile to blow out the soot build-up that you have from the dirty air cleaner.
   / What's m'diesel saying when he covers me w/soot? #3
Is it time to change the filter? Does cleaning it get out everything?
I had the filter in my gasoline powered generator become clogged with oil (IMHO). The filter only had 20 hours on it and the engine would not run with it. I put in a new filter and it worked fine. I think the oil migrated from the oiled prefilter to the paper filter. I now leave the prefilter off unless I am running the engine for many hours. This is not often since I only use it during power outages.
Bob Rip
   / What's m'diesel saying when he covers me w/soot? #4
Just curious.
How many hours between your air filter cleaning?
I got 30 hours on my 1850...mostly bush hogging, and as soon as I can, I'm checking mine.
/forums/images/graemlins/tongue.gif
Er... gee Dad... howcum you gotta ask those kinda questions??
I'd NEVER checked it. so... 90 hours. /forums/images/graemlins/blush.gif
I got conflicting opinions about cleaning it out with the air hose. The manual said it was ok, my rural neighbors are saying better to wash it with water and then set it out to dry in the sun. They are worried about tearing it if you hit it too hard with the air.
   / What's m'diesel saying when he covers me w/soot? #6
I had a similar problem on my Kubota, smoked really bad, limiting my rpm's. With no filter, ran great. Put in a new filter, still smoke. After investigating more, I discovered a rats nest down in the intake tube, which is about a foot and a half long before the filter, cutting off most of the air. Cleaned it out, and now works fine.
   / What's m'diesel saying when he covers me w/soot? #7
I blow out my combine filters daily during the 6 weeks harvest lasts, that's two filters per combine x 2 combines, never have had a filter fail due to the air pressure. If you're worried, turn your regulator down to about 45 psi and then your worries will be minimal.
hope this helps
   / What's m'diesel saying when he covers me w/soot? #8
P.S. if it's been 90 hours since cleaning, the dirt might be too embedded to clean by either method.
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
2014 MACK PINNACLE (A55745)
2014 MACK PINNACLE...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A56435)
2008 Ford F-250...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
Club Car Carryall 2 Electric Utility Cart (A55853)
Club Car Carryall...
2010 INTERNATIONAL DURASTAR 4300 SWEEPER TRUCK (A51406)
2010 INTERNATIONAL...
