What's in your tractor toolbox?
   / What's in your tractor toolbox? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
What's in your tractor toolbox? All I've got is an adjustable wrench to loosen the toplink nut, a large pair of pliers, extra click pins, some CAT 1/CAT II adaptors and a pair of leather gloves. You?
Oops--forgot the rag to wipe hydraulic ends.
   / What's in your tractor toolbox? #2
Interesting. I think i have;
Fence building pliers
Slip joint regular pliers
Variety of bushings, pins, etc.
Flat puncture fixing kit
Short handle 2 lb shop hammer
Older pair of leather gloves
Rag for wiping of hydraulic hose ends
   / What's in your tractor toolbox? #3
Mines got everything but what is required for the job at hand!
   / What's in your tractor toolbox? #4
Since I replaced that small tool box with a larger tool box, I have too much to list.
Several things I can't do without are:
WD40
Slip joint pliers
Short handle shop hammer
A small pipe wrench
1/2" socket set
Large Phillips screw driver
Several ringed and hairpin pins
etc.
   / What's in your tractor toolbox? #5
I have an adjustable wrench, pair of slip-joint pliers, nut driver that fits the hose bands on my leaf vac, and some spare lynch pins. That's been all I've needed for the past 20 years.
   / What's in your tractor toolbox? #7
Everything I dont need at the time something breaks .
   / What's in your tractor toolbox? #8
I replaced my small factory toolbox with a more generous sized one I built myself in a welding class. Besides the usual adjustable wrenches, replacement pins/clips etc and screwdrivers, I also have a little "hydraulic quick connector" kit that consists of a 2" piece of 3/8" steel rod and a ball peen hammer and some rags. When the unconnected quick connectors are pressurized by the sun's heat, I can tap the male with the hammer and do likewise for the female with the steel rod insert and hammer to open things up. Rags to clean my hands/gloves afterwards.
My toolbox also contains a few short sections of chain and shackles used to secure odd items that need lifting. I need to lift a swimming float in and out of the ocean over a seawall twice a year using a tree boom and always forgot where I left the chain and shackles until I just started keeping them on the tractor. Very convenient now.
   / What's in your tractor toolbox? #10
Plus a chipping hammer for the ice buildup.....at my feet is an old tire iron as well.
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2020 Freightliner Derrick Digger Truck (A55973)
2020 Freightliner...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
1629 (A57192)
1629 (A57192)
2017 Mercedes Benz GLA SUV (A56859)
2017 Mercedes Benz...
2016 Ford Explorer AWD SUV (A54815)
2016 Ford Explorer...
