What's happening with my mower blades?
   / What's happening with my mower blades? #1
Onthelake
East Texas
What\'s happening with my mower blades?
I am at a loss as to what is happening to my blades on my JD L130 with 48 inch deck. I bought it used last year. The blades that were on it looked like someone had taken a grinder to the trailing edge of each blade. The part that bends up to give the grass lift was gone almost totally. I actually thought someone ground it off for some reason. So I put new blades on. Now I'll admit that if it cuts, I don't go looking for problems. But last weekend I happen to look at the blades. They were the same, the trailing edge gone. What's happening to my blades? I live where th soil is sandy. Could the sand be blasting my blades away? The leading edge was still reasonably sharp.
Rod
   / What's happening with my mower blades? #2
Re: What\'s happening with my mower blades?
Sand is blasting your blades away, try to raise the height of the deck a little to see if that helps decrease the erosion of the blades.
   / What's happening with my mower blades? #3
The blades on an L series mower deck are very light duty. I put a set of Gators on my L100 and that took care of the problem. I still have to put the bagging blades on in the fall when using the rear bagger.
   / What's happening with my mower blades? #4
With sandy soil & light duty blades, you will probably only get one yr. out of them.
I never saw anything like this before. Of course I never had sandy soil. This could get expensive. Think I'll look for better blades. Thanks for the replys.
Rod
   / What's happening with my mower blades? #6
I have a friend who lives by the Mississippi river( sandy soil!) and he says he's lucky to get a year out of his Massey's blades.
   / What's happening with my mower blades? #7
</font><font color="blue" class="small">( I never saw anything like this before. Of course I never had sandy soil. This could get expensive. Think I'll look for better blades. Thanks for the replys.
Rod )</font>
I see it about 3 or 4 times a year on my Craftsman 42" riding mower. The sand really eats them up fast.
If you have a Tractor Supply in your area you might try them for blades. I have not used their blades but I am going to when I need some more. They are $10 per blade at TSC and $15 a blade at Sears so even if they don't last longer at least I will save $10 per set of 2.
Bill Tolle
ALLISON TRANSMISSION (A53843)
ALLISON...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A53426)
2015 UTILITY VS2RS...
2004 BMW Sedan (A51694)
2004 BMW Sedan...
2013 KENWORTH T800 DAY CAB (A54607)
2013 KENWORTH T800...
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
