Whats better mechanical or digital fuel meter for transfer tank
   / Whats better mechanical or digital fuel meter for transfer tank #1
jocww
SF Bay Area, Ca
JD 550c, 443 bobcat, had an old john ford FEL gone
Whats better mechanical or digital? Why is the digital meter cheaper than the mechanical GPI at TSC? Is it better or was it mis marked and I should drive back and get it? This will be for 100gal tank in my bed. That I use to fill up our dozers, tractors etc. So it doesnt have to be industrial strength but I wouldnt mind that.
TIA
Jon
   / Whats better mechanical or digital fuel meter for transfer tank #2
Personally, I will always get the mechanical/analogue type whenever possible.
Yes, in this day and age digital is less expensive but, in my experience, they don't last as long or are as robust as the mech/analogue device. The same thing goes, for example, a washing machine or dryer... digital goes 'down' & you have to replace the entire control front. Analogue, you just have to replace the relevant switch/knob.
You get what you pay for.
How do you like your mechanical one? Has it held up?
   / Whats better mechanical or digital fuel meter for transfer tank #4
I don't have one specifically for my transfer tank as it's only a 50ltr.
That being said, a digital meter would require a power source of some sort IOT keep the data and operate. Even whilst not in use, a 'keep alive' current would be required... even if it's a AA battery. Which you'd need to monitor occasionally to ensure that it doesn't run out.
A mechanical wouldn't require that.
   / Whats better mechanical or digital fuel meter for transfer tank #5
I'll echo Wagtail's comments in post #2. I would have not been as perfectly descriptive as using the word "robust", I would have said cheap or un-reliable, while robust hit's the nail on the head. :drink:
   / Whats better mechanical or digital fuel meter for transfer tank #6
I'm not certain which is better but I haven't had any problems with mechanical ones. Here's one on my pickup truck tank. IMG_2901.JPG
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2017 JOHN DEERE Z950M LOT NUMBER 83 (A53084)
2017 JOHN DEERE...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A55218)
Ditch Witch 6510A...
Utility Trailer (A52377)
Utility Trailer...
200722 (A51247)
200722 (A51247)
