What's ailing my 4610?
   / What's ailing my 4610? #31
Re: What\'s ailing my 4610?
If u can get the neighbor and the MF again
try using the loader to lift front wheels and/or
let it roll back to make sure it isn't froze down.
Another option is run chain under the bucket and
hook onto front of tractor and keep your bucket low
(more down force on the rear of MF).
Did u get the mule out from behind?
If the MF has a loader bolt a hitch to the bucket
and get behind your tractor (take off the tiller?)
and pin to your draw bar, this way he can lift some
weight from tractor and give him more traction.
Seems like u can push more than pull.
If u were closer to me I have a 12,000 lb.
hydraulic winch that a small subframe chained
to a tree or your loader bucket and pull u right
out.
   / What's ailing my 4610? #32
Smokeymtnman...
Hope you are on vacation or something just as much fun!
Please don't forget to let us know how things worked out!
Bill in Pgh, PA
   / What's ailing my 4610? #33
Hey Smokymtnman, what is the latest with the 4610? Haven't heard anything since the end of January.
Still the same, I'm afraid. I've had two promises for a dozer over here but neither showed up, one won't answer phone, other i dont' know what the deal was. Weather has been too bad, muddy, snowy, etc to do anything else. I've tried a few things others mentioned but I've decided I ca'nt do anything until i get it out and on level ground.
   / What's ailing my 4610? #35
SmokyMtnMan,
I know I speak for everyone here...
Keep your chin up...as you certainly seem to be doing!
We are all behind you in getting this problem behind us!
   / What's ailing my 4610? #36
</font><font color="blue" class="small">( Still the same, I'm afraid. I've had two promises for a dozer over here but neither showed up )</font>
SMM, anything new???? Please let us all know.
   / What's ailing my 4610? #37
Is it still out in the woods? /forums/images/graemlins/confused.gif
Jeff...U.P. of Michigan, and fellow L4610 owner.
   / What's ailing my 4610? #38
SMM,
It's been a month since your last post. Have you had any good luck/results?
   / What's ailing my 4610? #39
The discussion got moved to This Thread .
It's still in the woods /forums/images/graemlins/frown.gif
   / What's ailing my 4610? #40
Thanks WVBill.
Geez, what a mess!
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 BRUMLEY MANUFACTURING DATA VAN TRAILER (A55745)
2012 BRUMLEY...
1986 Betenbender 175 Ton 10 Ft Press Brake (A59213)
1986 Betenbender...
2017 Bobcat T770 Compact Track Loader (A56438)
2017 Bobcat T770...
CAT Chassis Only (A59076)
CAT Chassis Only...
202475 (A54757)
202475 (A54757)
