Whats a good way to catch xmsn oil?
   / Whats a good way to catch xmsn oil? #21
Jeff244: do you just slip the vac hose over the fill tube loosely, or do you tape it closed? Sounds like a good way to accomplish the above.
One of my attachments is long and pointed, it fits tightly into the filler hole. I screw it in a turn or 2 which makes it a very good fit. I do use duct tape where the attachment connects with the hose just to make sure it doesn't get disconnected and to cut down on air leakage.
Jeff
   / Whats a good way to catch xmsn oil? #22
Just replace the drain plug before the drain pan fills up. Put an empty pan back under and resume draining. I don't see the problem?
Trying to get that big plug back in can be a real pain. I have had the warm fluid run clear down my arm to my shoulder. Someone I think here, posted the axle drain plug idea, and I have used it with great success.
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2016 INTERNATIONAL 4300 26FT BOX TRUCK (A56129)
2016 INTERNATIONAL...
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
2013 MACK CHU613 (A58214)
2013 MACK CHU613...
John Deere 4510 (A53317)
John Deere 4510...
Water Line Hose (A59076)
Water Line Hose...
