what year is my DADS 2000 ford tractor
   / what year is my DADS 2000 ford tractor #11
50 year old tractor. Could have easily had an engine Swap
   / what year is my DADS 2000 ford tractor #12
Point.
   / what year is my DADS 2000 ford tractor #13
I am also looking for some info/help.. I have just recently purchased a ford 2000 .. I have 2 numbers but it just doesn't seem to add up.. the numbers are:
6M7B
21022A
C158881 6MB
as I read this it is a 2000, but where it gets confusing is that mine has a diesel engine.. but that number indicates a gas engine..any and all help/information is greatly appreciated.
Travis
I'm not sure what / where you are getting your bad info.. Maybee it's because you are thinking it is a VIN code.. ford tractors don't have VIN codes.
the have model ID numbers, serial numbers, and date codes. and you have all 3, and they are VERY easy to decipher
21022A This is a model ID.
2 = 1965- 3/1968 ford 2000
10 = Ag chassie
2 = gas engine
2 = trans 540 pto
A = 4 speed
As was said.. engines get changed.. and so do transmissions... could have been a trans swap.. or engine..
C158881 is a serial number. It puts it as a late 66 model. 1966 SN range started with C124200, 1967 SN range started with C161300
6M7B is a date code. 6 = 1966 M = December 7 = day of month B = B / DAY shift Dec, 7, 1966 which goes along with late 66 sn.
   / what year is my DADS 2000 ford tractor #14
I thank you all for the information, I hope to use this site for quite a bit of changes that I am wanting to do to my tractor.. not particularly fond of the transmission PTO, but it is what it is.. I will just have to adjust to using it.
Travis
   / what year is my DADS 2000 ford tractor #15
Unless you are running a hay bailer, it isn't much of an issue to overcome the limitations of a non live pro. Just remember to use an orc if running a high inertia implement, like a rotary brush mower.
2026 Anvil Trailer (A56859)
2026 Anvil Trailer...
2016 CATERPILLAR 262D SKID STEER (A52709)
2016 CATERPILLAR...
Bucket (A55973)
Bucket (A55973)
John Deere 853 20ft Corn Head (A56436)
John Deere 853...
2018 John Deere 4066R (A53314)
2018 John Deere...
Bucket (A55973)
Bucket (A55973)
