What year built?
   / What year built? #1
codger
Nead info on IH 275 diesle. Who made the motor ?
Is there a site with IH serial # ?
My 275 has devloped a motor noise, not good.
We have some poor dealers in my area, so I nead as much info on the machine as I can get before I let them
near it .
Thanks AL H. {codger}
   / What year built? #2
I tried a quick Google search. You might ask that question further down the main page on the Case-IH specific site.
   / What year built? #3
CaseIH 275
General tractor information:
Manufacturer:CaseIH
Model:275
Type:Farm/Agricultural tractor
Years produced:1986 - 1991
Total built:
Factory:
Original price:$13,100 (1991)
Tractor power:
Engine:31 hp [23.1 kW]
PTO (rated):27 hp [20.1 kW]
Engine:
Manufacturer:Mitsubishi
Fuel:diesel
Cylinders:3
Bore/Stroke:
Displacement:91.3 ci [1.5 L]
Compression:
Rated RPMs:
Cooling:
Torque:
Firing order:
Transmission:
Type:synchromesh
Forward:9
Reverse:3
Mechanical:
Chassis:MFWD optional
Steering:
Brakes:
Capacity:
Fuel:7.4 gal [28 L]
Coolant:6.3 qts [6.0 L]
3-Point Hitch:
Rear Hitch Category:I
Rear lift:1544 lbs [700 kg]
Power Take-off (PTO):
Rear PTO:live
Rear speed (RPM):540,1150
Hydraulics:
Type Open
Capacity:26.4 gal [99 L]
Total flow:
Outlet flow:7.3 gpm [27.6 lpm]
Pressure:
Outlets:1
Tires:
Ag front:6.00-16
Ag rear:13.6-24
Dimensions:
Weight:2600 lbs [1179 kg]
Wheelbase:71 inches [180 cm]
Length:
Width:
Height:
Ground clearance:
Electrical:
CaseIH 275 links:
Tractors from 1986-1989 had Nissan engines, later versions had Mitsubishi, according to Used Tractor Guide.
   / What year built? #4
Serial number located right front frame;
Year Beginning Serial #
1986 17656500
1987 17656510
1988 CCJ0028001
1989 CCJ0028615
1990 CCJ0029301
1991 CCJ0029992
1992 CCJ0030672
2005 PETERBILT 379 (A53843)
2005 PETERBILT 379...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
2012 FREIGHTLINER DURASTAR 4300 M7 SBA 4X2 BUCKET TRUCK (A51406)
2012 FREIGHTLINER...
U56 ELECTRIC FIRE PUMP MOTOR (A51406)
U56 ELECTRIC FIRE...
Chery 7' 35 Drawer Workbench (A50120)
Chery 7' 35 Drawer...
