What would you do
   / What would you do #1
coryip
ny
deere 4200 hst
Hello all
Looking at a Bobcat and will be purchasing in the next day or 2 but am trying to decide on which one. A CT235 or CT335SST that is $600 dollars more. I have had a hydro before and have also used SS tranny tractors also. Will be using for clearing, driveway maint., moving dirt, mulch, stone, and snow. Just wondering if its worth the $600 extra for a heavier machine 700lbs, 3pt lift cap is higher 200-800lbs, loader lift height is more 14", but i would be giving up the hydro. The hydro 335 would be nice but prices seem to be $1500-$2000 more.
Thanks for any help in this decision.
Also if anyone has a coupon i would greatly appreciate it.
   / What would you do #2
Depends on how bad you want the hydrostat transmission.
Personally I would go with the CT335SST.
   / What would you do #3
I just got a coupon, just let me know where to send it. (oh and for less than 25 acres I would opt for the 235, but that's just me.
   / What would you do #4
I was on the same boat as as you are, not long ago. I visited 3 dealers and after talking to Rick Wallace on "wants and needs", I ended with the CT235 and will be deliver on Wednesday. I actually went up with CT440 after trying one but I only have 4 acres to take care. And with the CT235... it is more than what I needed. Between your two choices... you can't go wrong :thumbsup:. Congrats on your purchase. Oh one more thing. Ask around if anyone still have their coupon. I got one from KS Kioti and he will have the other half to purchase the implement. Just need to give him the serial number of my new tractor.
   / What would you do #6
I have a CT450 SST and love it awesome power and its all useable, I had a 440 hydro for a year and 109 hrs and it just didnt cut it!! If you like geared tractors you will ove the SST 335 im sure.
BTW I hv a coupon if you need it PM me.
   / What would you do #7
I see you have 3 acres.
The CT235 with hydro may be a better fit.
   / What would you do #8
The 235 is more tractor than you,ll need.I just got to the 180 hr. mark and I use it every day and is a very good machine:thumbsup:Dave
   / What would you do
Yes i have about 4 acres and it will also be used on my father-in-laws 6 acres across the road. It is going to be a joint purchase and he is really attracted to the larger machine. If i left it up to him he would come home with a full size backhoe and luckily i have been able to steer him away from that mistake.
My old tractor was a JD 4200hst and i always felt it was a little too small. I have also read that the high range with the hydros feel weak. Has anyone else noticed that. Even with my JD on open road in H range it would not hold a steady speed unless on flat or downhill even the slightest grade would start to bog down with the RPMs up. Not that this is a huge concern since i rarely needed to use H anyway.
Does anybody make a cab that can easily be put on and removed. I like cabs but find them to be more off a hassle in anything but very cold weather due to the restrictions on seeing out and around the machine.
Thanks for everyones input so far and going by what i have seen it looks to be a toss up.
   / What would you do #10
With 10 acres to maintain I'm going to go with my first post and recommend the CT335.
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
Set of Ag R4 Wheels and Tires (A52748)
Set of Ag R4...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A52748)
2018 John Deere...
2020 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2020 Ram 1500 4x4...
2021 Ford F-150 XL (A50120)
2021 Ford F-150 XL...
40' Sea Container (A50774)
40' Sea Container...
