what would have done?
/ what would have done? #1
valley
Platinum Member
mountain valley near Tahoe
Michigan 55A, Foton 254
Greetings, Today, I cut a fire break around a good neighbour's place, couple hours. I saw a hydraulic leak up behind the big ram on the back hoe. I was undaunted, I drove out the pin holding the ram, tightened the hydraulic line, drove in the pin, set and the lock. It was time to reinstall the sheet metal over the transmission, I had taken it off to seal a leak between the trans and the gear box in front. I drove out the pins and removed the levers and gear shift knob. Having the sheet metal in place I reinstalled the levers. Using drifts I was able to get the bolts in place. The one thing I couldn't find is the gear shift knob. It was right here. I looked, I called my daughter, she looked. We checked in the tool box, we checked here there and everywhere. I put away the tools, wiping them first. I tried not to think, that it might be under the sheet metal I had just installed. I went inside built a fire and poured a large brandy. If it were you, What would you do?
/ what would have done? #2
drill out a golf ball pour epoxy in slap it on and have another brandy!
ELLIOTT MAGNETEK 60KW DIESEL GENERATOR (A67714)
ELLIOTT MAGNETEK...
Hoelscher 110 Bale Grapple (A64126)
Hoelscher 110 Bale...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
2016 Nissan Pathfinder 4X4 SUV (A66738)
2016 Nissan...
2023 Kubota L4802DT 4WD 48HP Utility Loader Tractor (A66734)
2023 Kubota...
17in. Bucket w/ Teeth Excavator Attachment (A68183)
17in. Bucket w/...
