What would be the BEST rough terrain tractor?
   / What would be the BEST rough terrain tractor? #41
What we used is nothing like the WoodsBoss setup, it is just a Very heavy duty 1960 brush hog type cutter that My friends bought at a GA DOT auction in the mid late 60's. It is an IH brand and was painted yellow from factory, not red and has a shadow of some DOT #'s and the IH trademark still visible. Data plate is long gone. I am not even sure of the cut but I think it is 7'. I didn't know IH built this type of cutter, have never seen another. Could have built or supplied it per State of GA bid spec or something. It is very heavy, even behind an old 3000 Ford diesel. Along with that I have a 4' LD Bush Hog cutter for zig-zaging through my woods and a Bush Hog RDTH-60 grooming mower. Friend has an older 6' MD Bush Hog cutter along with the old DOT monster above. We now have lots of trails for ATV's, dirt bikes. Have a nice fire-pit area and a nice large area set up as a shooting range set up with targets ranging from small paper bullseyes up to 55 gal drums and one 1969 Toyota coupe; now a convertable....
So, I'd love to pick your brain about some things.
When you were creating the ATV trails and such, what was your method for clearing? I mean, did you just drive over the saplings and briars and what not and then let the bushhog chop it all up? Or did you push that stuff over with a FEL and then drive over? Or did you first back the bushhog over the saplings and stuff? Did you have issues with either method just leaving sharpened stakes/stumps behind?
Also, you got any before/after pics?
   / What would be the BEST rough terrain tractor? #43
Did a lot of backing into some areas due to stumps from firewood cutting. Also occasional junk/projects brought home by family members over the years that got thrown on the back property lines along with tresspasser dumping, un-confirmed native American burial sites, a few rock outcroppings, a few rockpiles from the farming days, old long gone barns/sheds, barbed wire, 1939? Dodge engine/trans/partial frame, 2 known wells, sawmill parts, ect......The hardest parts to clean up are some of the areas that were puplwooded due to the fact that they used loaders to push debris in piles that were about 6' tall and 12'-15' and contain rocks and stumps mixed with clay. A few of these piles still exist after 14 years. So most areas were pre-walked, then backed into with the cutter raised high and then cut at lower levels later. Since most these particular areas were farming fields that when left unused years ago; turned to pines, and then pulpwooded, most of what has to be cut is small pines and all the junk vines and briars. The remaining stumps can in areas where you want to drive can be cut lower with saw or in the case of small siameter softwoods just cut off at ground level with loping (sp?) shears so as not to damage sidewalls. Most of what we have to rough cut now is stuff that was done 20-25 years ago but has been neglected for 1-3 years at a time. The rest is just field grass that gets cut about 4 times a year. Not as much gets done as in years past as all the nieces and nephews that we taught to ride motorcycles, horses, and shoot guns have all grown up.
   / What would be the BEST rough terrain tractor? #44
<font color="blue"> Did you have issues with either method just leaving sharpened stakes/stumps behind? </font>
A lot of the small stumps that are left will not be cut off clean like a lawn mower does. A brush mower as some have put it more like beats the brush off instead of cutting it. That leaves a stump that is really beat up. Of course there are a lot of different factors that will determine the extent of this. Moisture in the plant, type of plant, previous growing conditions etc all play a part.
So, on the topic of rough terrain tractors:
1. Antonio Carraro
2. Massey-Ferguson 400 series
3. New Holland ??
I haven't heard anyone from the Kubota, Deere, etc. crowd.
Anything in those lineups that would be good for steep terrain??
   / What would be the BEST rough terrain tractor? #46
There is a big bad A$$ Mahindra 6500 on ebay right now for an excellent reserve price. That with loaded ag tires, and a hefty rear Woods ballast blade would get you pretty far with the work you are wanting to do. The Mahindra in my opinion aren't as refined as the NHs, Deeres, but for a mighty brute tractor with deep growl, which is what you need. You would be hard pressed at that reserve price to match it. /forums/images/graemlins/grin.gif My 1971 IH3444 is a Mahindra built, Perkins direct injection diesel, with an IH 3141 hoe, and a South Korean FEL. It is a beast, and **** near unhurtable.
   / What would be the BEST rough terrain tractor? #47
Well, not necessarily "rough" terrain, but certainly steep terrain -- designed and built in Switzerland:
Their whole product line:
http://www.aebi.com/
   / What would be the BEST rough terrain tractor? #48
Raw,
Someone posted this in the NH forum. Looks right up your alley (or slope that is)
web page
   / What would be the BEST rough terrain tractor? #49
I wouldn't consider the Mahindra 6500 a competent tractor for slopes. I don't know that Kubota builds anything for that type of terrain either. They do build narrow tractors, but that isn't the same thing.
I really like the NH TK-A. Can you put a FEL on that beast? If so, it might be the perfect fit. /forums/images/graemlins/grin.gif
   / What would be the BEST rough terrain tractor? #50
</font><font color="blue" class="small">( I don't know that Kubota builds anything for that type of terrain either. They do build narrow tractors, but that isn't the same thing.
)</font>
Kubota M9000 Low Profile, if it has sufficient ground clearance.
   / What would be the BEST rough terrain tractor? #51
Those New Holland crawler look like the perfect solution, /forums/images/graemlins/cool.gif but I don't think think their avalible with a FEL, /forums/images/graemlins/frown.gifwhat about a blade? /forums/images/graemlins/confused.gifAlso what the price for one of those. probly cost a pretty penny, new at least. /forums/images/graemlins/crazy.gif
a FEL is crucial.
Speaking of which, I just got word that Westendorf is going to be producing a FEL for the Antonio Carraro tractors.
   / What would be the BEST rough terrain tractor? #53
The thing with crawlers are- they just crawl- You need something on wheels that can take you around. Wheeled tractors are much more versatile. Besides, crawlers are dangerous, on frozen ground they slide sideways (a friend of mine got killed that way) in steep muddy slopes they goes too far before they give up. And they leave tracks, and tears up the ground. Rent a tracked digger from time to time when you need something done, or buy one in addition to a tractor.
   / What would be the BEST rough terrain tractor? #54
Have you considered a Unimog? Take a look at the Case MB4/94 model - I am considering one to supplement my TN75
You can get these with F&R PTO & hydraulics, 2WD, 4WD, or all 4 locked, side slope capability of 42% and verticle of 60%
I'm waiting for Vonn to jump in anytime, as he is the resident expert on MOG's /forums/images/graemlins/cool.gif
Here is a link to Vonn's site - click on the left had side on the brochure to see some of the capabilities http://vonsmog.tripod.com/
I love Unimogs but didn't realize they'd run front & rear hydraulics.
HMMMMMMmmm.
I've been in the HUMMER world since '95. And that's the kind of offroad ability I'm used to. A Mog would be pretty similar in abilities.
Where can you find attachments that will work with the MOG. I assume that once you get a 3PH for the rear, any 3point attachment will work, right?
What about the front loader? How do you get your hands on one? Can you swap out the bucket for a plow? Or would you need a whole different front end attachment for the plow?
I'd much rather spend 20K on a Unimog than a tractor, personally. But I've got an irrational fondness for the mogs.
   / What would be the BEST rough terrain tractor? #56
</font><font color="blueclass=small">(
)</font>
uhhh the mog will stomp a hummer offroad. not similar at all IMO.
<edit>
I relized just now I spewed off ...
approach/departure/breakover angles ... mog wins
gearing ... mog wins
flex ... mog wins (H1's are stiff)
"beef" ... both are beefy
"HP" ... who cares ... it's the gears and wheels on the ground
</edit>
still IMO ...
(ohh and H2's buhahahaha)
Depends on the driver and the truck, but . . . don't want to get into that argument. I've seen Mogs roll over where a HUMMER wouldn't. I've seen HUMMERs stuck where a Mog wasn't. Totally depends on the situation.
I know they're totally different trucks (solid axle versus independent, etc.) But they have geared hubs and large clearance etc.
Just saying that they're built for similar uses (as opposed to a Z71 Chevy or something).
   / What would be the BEST rough terrain tractor? #58
Thought that might get your attention /forums/images/graemlins/cool.gif
I'm still learning on the Mog's too, so can't answer all your questions, but it does appear to be more difficult to find some of the attachments - ie. you may end up having to import or wait until you find here in the US. There are many configurations available though
Mog's have been used, and still are, in Europe for Ag related for many years. Freightliner is dist. for the newer Mogs - if you have $100K+ /forums/images/graemlins/blush.gif
There are Mog sites that have more knowledgeable people to answer your specific questions. I believe TBNer DangerousDan uses Mogs in his logging work and some others on here have them as well.
Some say a MOG is a Hummer tow truck /forums/images/graemlins/grin.gif but I wouldn't know
   / What would be the BEST rough terrain tractor? #59
I've heard the term H.R.V.... Hummer Recovery Vehicle. /forums/images/graemlins/wink.gif
   / What would be the BEST rough terrain tractor? #60
I thought I downloaded a sticker for it. Here it is (see attachment).
2014 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2025 Swict 84in Bucket Skid Steer Attachment (A59228)
2025 Swict 84in...
iDrive TDS-2010H...
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
Case skid steer wheels and tires (A56438)
Case skid steer...
2025 HT360W Mini Stand-On Track Loader Skid Steer (A59228)
2025 HT360W Mini...
