What works to remove class 3 HST oil filter?
   / What works to remove class 3 HST oil filter? #1
farmacist
Saranac, New York
TC35D
I always have trouble removing my (small) HST oil filter on my class 3 (TC35D) because of the tight clearance between the loader frame and the oil pan. It sits up at least 3" and only has 1/4" clearance between the loader frame and the filter. Have you found a wrench that will reach up there and grab the filter? I have tried 3 or 4 end cap types and they all seem to slip. There is not room for a strap. What do you use and does it really work? Thanks Frank
   / What works to remove class 3 HST oil filter? #2
I use a snap-on strap wrench on mine
   / What works to remove class 3 HST oil filter? #3
My universal filter removal tool has never failed me.;)
   / What works to remove class 3 HST oil filter? #4
A cheap strap wrench off the K-D rack at NAPA is all I ever used. When I was at the dealership I changed many more of those filters on Class III tractors than yours will ever need.
   / What works to remove class 3 HST oil filter? #5
LMAO Yep, the old two fisted screw driver never fails me either. :D
   / What works to remove class 3 HST oil filter? #6
I have done that more than I care to admit, but I just bought one of the tools shown in the attachment and haven't had a chance to try it yet. I've been using a strap wrench and ratchet like RickB noted most of the time. :)
   / What works to remove class 3 HST oil filter? #7
I use a strap wrench too.
Bob
   / What works to remove class 3 HST oil filter? #8
I've found a " 2'' TO 4-1/4'' OIL FILTER WRENCH " at Harbor Freight
to get at some of the tightest places a strap on won't get.
   / What works to remove class 3 HST oil filter? #9
Great information here! I'm going to check out Harbor Freight.
I must admit, I've used "Jinman's Universal Oil Filter Removal Tool" on more than one occassion.
5ft 3 Point Hitch Bog Harrow (A51573)
5ft 3 Point Hitch...
2006 HAMM HD120HV SMOOTH DOUBLE DRUM ROLLER (A51246)
2006 HAMM HD120HV...
JOHN DEERE 8R 340 LOT NUMBER 96 (A53084)
JOHN DEERE 8R 340...
CAT Skid Steer (A50322)
CAT Skid Steer...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
