Grading What works a tractor harder?
   / What works a tractor harder? #31
I know kind of an old thread but the guys saying it takes the same are correct from my experience. I can kill a tractor mowing or tilling. All depends on the ground speed, depth your tilling, what your tilling, thickness of grass, type of grass. RPM is dictated by all of those variables. This is a "It depends" question that cannot be really answered.
   / What works a tractor harder? #32
I have to disagree with most of the guys here. When tilling, you are going so slow that the tiller is not really engaging the tractor in a pulling contest or PTO HP contest. The blades turn so fast that mostly they are just remixing the soil with just a bit of new dirt being chopped in at each turn. Going faster only makes the tiller come out of the ground so it really doesn't load my tractor any more going faster vs slower. I cant even tell when my tiller is engaged by looking at the RPM but I sure can when engaging the bush hog. I can stall the engine bush hogging if I go too fast in super tough conditions but cant see any stalling in the tiller regardless of speed of travel.
Pulling a disc harrow is more conducive to stalling and more of a comparison to the bush hog for power needed to operate.
   / What works a tractor harder? #33
As said earlier, both tilling and mowing take exactly the same power.
Running at full rpm doesn't mean you are producing full power. You are running at full power with both implements, but you are working way longer per acre with the tiller.
Yeah. More energy, work, per acre.
Running at full rpm doesn't mean you are producing full power. You are running at full rpm with both implements, but you are working way longer per acre with the tiller. ,,,:confused2:...
,,,,,,,,,,,,,,Unfortunately, after I answered the original incohesive post you edited it into incoherence.
   / What works a tractor harder? #34
If your going too fast and your tiller is coming out of the ground your not really tilling (or at least not like you want to). That would be like saying your mowing two foot grass but your only cutting off half way down so you could go faster at that too but you wouldn't be cutting it like you want to. It's still mostly about ground speed. Pulling a ground engaging non rotary implement wasn't in the original comparison posted but I do agree with you that can take a TON of HP depending on the variables.
   / What works a tractor harder? #35
You have a special case where there is surplus hp ... or a tiller that is too small or light in weight.
   / What works a tractor harder? #36
I run a 6" tiller on my 35 HP tractor.
If I'm tilling previously tilled area I till with ease.
If I'm tilling full depth in an untilled area it will take most all the power I have.
   / What works a tractor harder? #37
Lets get back to basics: It takes a certain amount of Energy to do a task.
Let's say it's pulling a log up a hill. Doesn't matter if you're using a 10 hp garden tractor (assuming traction) geared down so low that it takes 20 minutes, or a 200 hp skidder that takes 1 minute. The "energy" both machines delivered is the same, only the rate (time required) differs.
Horsepower is a measure of the RATE (I.e. speed) of applying that energy.
When people ask how much horsepower do I need to do a task (snowblowing, tilling, mowing etc...) it's sort of the wrong question.
Because the answer is ALWAYS another question: Well, how fast do you want to go?"
   / What works a tractor harder? #38
,,,,,,:thumbsup: ... Now the blanks are all filled in. ;)
   / What works a tractor harder? #39
You mean something like this:
https://www.youtube.com/watch?v=13Yz_KCEN8M
   / What works a tractor harder? #40
Pretty much the way I see it^^^^^^
(3) TRAILER AXLES FOR PARTS (A57192)
(3) TRAILER AXLES...
2020 FREIGHTLINER CASCADIA SLEEPER (A57880)
2020 FREIGHTLINER...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A51692)
2016 Autocar...
Flat bed utility truck with inline 6Cy engine (A55315)
Flat bed utility...
48in Farm Jack (A55852)
48in Farm Jack...
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
