Grading What works a tractor harder?
   / What works a tractor harder? #1
knukey
Bronze Member
Richmond, VA
Mahindra 2015 Gear/Loader
What works a tractor harder a rotary cutter (cutting 2' field grass) or a tiller (cutting thru 6" dense field grass)?
I guess I'm pondering which requires more HP?
   / What works a tractor harder? #2
Ground contact work (tilling) requires more tractor power than non-ground contact work (mowing).
   / What works a tractor harder? #3
Depends on the width of the implementsame being compared. If they are the same width, the tiller hands down.
   / What works a tractor harder? #4
I disagree It takes a lot more power for a mower than a tiller. 2ft tall grass will bog many tractors and a tiller is easy in one. I have a 5 ft deck and a 5 ft tiller.. Ed
   / What works a tractor harder? #5
The tiller, no comparison especially if you operate at the same ground speed.
   / What works a tractor harder? #6
The only time I have had my B2620 near over heated was using a tiller. Never had it close bush hogging unless the radiator was plugging up with chaff.
Will
   / What works a tractor harder? #7
With our 32 hp machine, if I'm tilling 6" deep, I'm in 1st gear @ PTO rpm (0.6 mph) with a 5' tiller.
2' & dense field grass, I'm in 3rd or 4th gear @ PTO rpm (1.9 or 2.3 mph) with a 5' brush hog.
From that I'd say tiller takes more power, by a factor of roughly 3 or 4.
-jim
   / What works a tractor harder? #8
I can run my tiller and do at around 1700 rpm's and the tractor has no problems. I run my bush hog at 2500 rpm's and I often bog it down. Talking about running a tiller at the same speed as a bush hog is silly. Ed
   / What works a tractor harder? #9
A lot of variables. I have bogged more using a cutter than a tiller, but it was at different speeds. You mow up steep hills but don't usually till these areas. I think it can go either way, but if I had to pick, I would go wit tilling since I seem to use more fuel per hour.
   / What works a tractor harder? #10
Guess it takes more power to run a tiller then.....
2023 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2023 Ford F-150...
1994 Chevy  2500 Dually Pick Up Truck (A50515)
1994 Chevy 2500...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
2019 NEW HOLLAND TS6.130 TRACTOR (A51406)
2019 NEW HOLLAND...
2014 TOYOTA 8FGCU25 FORKLIFT (A51222)
2014 TOYOTA...
