What Wires Did I Cross?
   / What Wires Did I Cross? #1
RDrancher
North Texas
New Holland
Long story short. I ripped out the trailer wiring on a stump with my F350. This happened to be the same day that I was rewiring my gooseneck trailer.
I hooked up the wiring back on the truck to the 6-way plug the way I thought it was supposed to go and then rewired the trailer and new 6-way plug...and everything worked fine.
But...
I rented a dump trailer, also with a 6-way and my Prodigy brake controller started flashing 5h which is described as "detects brake wire short during idle condition". No trailer brakes and only one brake light. I thought their trailer was messed up, but then I rented another brand new dump trailer the other day and got the same thing.
Obviously I crossed wires somewhere on the truck. Is there anyway to tell which ones without starting from scratch?
   / What Wires Did I Cross? #2
Go to R&Pcarriages.com They have all the wiring diagrams you need under the help section.
Just be warrened, 6 way plugs are old tech. Everyone is using 7 ways now days. A big issue with a 6 way is there is two standards to wire them. So your truck may work with one trailer and not with another. This has been a issue with them for 20 years now and us the reason every manufacture went to the 7 way.
Chris
   / What Wires Did I Cross? #3
there are 2 6 pin wire 'standards' using the wrong standard puts power to brakes full time.. thus plugging in t he plug starts warming things up.
my old dodge had a 6 pin and my flatbed is 6pin.. i sodl the dodge and all my stuff is now 7pin. i need to convert the flatbed and horse trailer.. will get 'roundtoit one day.. till then i use a hoppy 6 to 7 adapter, that you can switch 2 wires internally to accomodate the 2 6 pin standards.
lets see if this pic link works
http://www.justanswer.com/uploads/crazi429/2006-10-02_222742_Trailer_connector.jpg
Sounds like I need to go to 7 pin. Luckily I only have the gn and horse trailer to change plugs on. BTW - The first dump that I rented was a 6 pin and the second a 7 pin that I found an adapter for after going to five or six places. Now I understand why all of the in-stock adapters were set up for 7 pin truck to 6 pin trailer.
66 Tomahawk Skid Steer Bucket (A52384)
66 Tomahawk Skid...
2010 John Deere 200 Crumbler Seedbed Finisher (A53117)
2010 John Deere...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
