What will come with a Round Baler when purchased
   / What will come with a Round Baler when purchased #11
Some older balers do not require electronics. There are indicators on the baler to tell when it is full and you use a rope for tying. Works really well and can be switched between tractors easily.
   / What will come with a Round Baler when purchased #12
Others still had a hand crank or a hydraulic cylinder and then there is manual controlled electric tie, which is what we still use.
   / What will come with a Round Baler when purchased #13
My JD 510 5X6 baler cost a $1000 4 years ago and has a hyd tie. Use it for about 10 to 15 acres a year. Doesn't pack as tight as the newer ones but the alpacas can eat easier than the neighbor's Vermeer tight bales. Repair cost have been one hyd hose and one belt.
   / What will come with a Round Baler when purchased #14
The first round baler I used was an international 3450. It was a soft core baler and it had a control box instead of a monitor, the box hooked up to the battery terminals for power and it would let off an alarm when it was full then you had to manually wrap the bale with a switch that moved an arm. It was very basic but was the easiest baler I have ever used, all my bales were perfect shape and never had troubles starting them (which I was told is the hardest part of making a bale.)
Tafe 45DI (A53317)
Tafe 45DI (A53317)
2010 KMC 3376 Peanut Combine (A56435)
2010 KMC 3376...
2014 Ram 2500 Pickup Truck (A55973)
2014 Ram 2500...
gps trailers (A56859)
New/Unused CFG Industrial QK18R Mini Excavator (A57453)
New/Unused CFG...
(4) 305/45R22 TIRES & WHEELS (A58374)
(4) 305/45R22...
