What welder would be best??
   / What welder would be best?? #91
Thanks for the info, Furu.
What was the brand that had the problems?
   / What welder would be best?? #93
I watched some welding videos and got some tips from them. Went out and tried to put them into practice and I guess it worked because I got what I would call some pretty good welds, but not all of them turned out great. I am still undecided but if I do get one I think I will get an everlast 140st. What are some tips that you blokes would suggest for improving my stick welding? Another thing is do you think automatic welding helmets are 'essential'?
I got a angle grinder stand for my 9in angle grinder, there is a slight bit of movement in pivot and so you can't get exactly square cuts but it is a lot better than cutting in from 4 sides with a 4.5in grinder. I am in the process of building a compost tumbler so that's what I experimenting on.
FYI ---- Just wanted to know if BLOKE was a dirty name ...
Bloke (word) - Wikipedia, the free encyclopedia
en.wikipedia.org/wiki/Bloke_(word)
Wikipedia
Bloke is a slang term for a man common in Britain, South Africa, Australia and New Zealand. The earliest known usage is from the early 19th century, when it ...
   / What welder would be best?? #94
Get some scrap steel and practice running beads on it until you can run a reasonable bead without to much trouble.
Watching someone who is a good welder will help.
Two books from Lincoln are also helpful. "How to use Arc Welding". "Arc Welding Lessons for School and Shop".
Automatic welding helmets are not essential, but are useful in certain situations.
Re Buying A Welder.
Take a look at this website. Magnum Welders - Home
Thanks for that R W.
Do you have a Magnum Welder? If so what do you think of it?
If I was to buy an auto welding helmet what would suggest I look for?
Will look at those books.
Thanks for your input.
   / What welder would be best?? #96
Don't have a Magnum Welder, but looked them over at a local field day and liked what I saw.
Can't comment much regarding auto welding helmets (have one but don't use it a lot). Main thing I'd suggest is to buy a good quality one.
   / What welder would be best?? #98
Got a everlast powerarc 140st today. :thumbsup:
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2022 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2022 Chevrolet...
set of 4 wheels and tires 205/75R15 (A56435)
set of 4 wheels...
1994 International 3800 Bus (A54814)
1994 International...
PORTABLE AIR COMPRESSOR W/ GAS MOTOR (A58374)
PORTABLE AIR...
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
