Buying Advice What valves do I want/need?
   / What valves do I want/need? #1
Lefty7
Finger Lakes, upstate NY
Kubota L3940HSTC, LA724, BH92, RTV-X1100C, 1978 Dodge D100 Adventurer (Sunrise Orange), 2018 Ram 2500 (Omaha Orange)
Planning on ordering a 3940L, w/cab, FEL and a tiller. Also will want the backhoe plus hydraulic thumb. Not sure if I can swing the hoe at the same time; might have to wait a year or so for that. But I want the tractor built correctly to accept it - whether it's now or later.
Unit will also see some post hole work.
Have gone through the builder on the Kubota website multiple times. I usually configure it with all 3 remote hydraulic valves: 2 double-acting and 1 float detent. Is this correct for my uses?
Also, as a loader valve option, they list: "third function valves for cab models".
For what possible applications would such valving be used or needed?
   / What valves do I want/need? #2
Have an L3130GST open station. Bradco 408 backhoe with a dedicated full flow backhoe circuit, that loops and disconnects three point and rear remotes. Also have 2 Kubota rear remotes, one regular and one floating for the top and tilt cylinders. On front have the WR Long third function valve for grapples and grapple bucket.
Do not use a Kubota rear remote circuit with bungee cord to run the backhoe, I think the plumbing is too small for full time use. Have heard of problems with the Kubota third function valve sticking from backpressure and would look and see what WR Long has for your tractor.
David Kb7uns
   / What valves do I want/need? #3
As mentioned grapple, but also for angle adjustment of a front snow plow blade is common. Or anything else you can think up and Fab up.
James K0UA
   / What valves do I want/need? #4
I have the Kubota third function(front) used for my snowplow angle and the thumb on my bucket.There has(have) been some problems with this set-up
Me included.I would recommend the W.R. Long set-up myself.
   / What valves do I want/need? #5
The third function provides intermittent flow for loader mounted implements such as a grapple or plow. Probably not enough flow to run most hydraulic motors. For a backhoe you will need a pro pump or a power beyond setup in addition to any rear valved outlets.
OK. That clears up at least some of the fog. Thanks JimP and k0ua, (sounds like a ham call), for the explanation; think I'm getting a handle on it (heh heh). Appreciate knowing about the possible shortcomings of the Kubota third function valve. So thanks nybirdman and David kb7uns (more call letters?) for that. I'll check in to the W.R. Long set-up.
Will probably have a few more questions.
   / What valves do I want/need? #7
OK. That clears up at least some of the fog. Thanks JimP and k0ua, (sounds like a ham call), yes for the explanation; think I'm getting a handle on it (heh heh). Appreciate knowing about the possible shortcomings of the Kubota third function valve. So thanks nybirdman and David kb7uns (more call letters?) Yes again for that. I'll check in to the W.R. Long set-up.
there are a bunch on here with callsigns for "handles" and really quite a few that use something else but are also hams.
James K0UA
James K0UA
Thanks for confirming. Don't have a ticket, just an SWL, but have 4 hams in family. 73's.
   / What valves do I want/need? #9
I too wanted to know about this, and asked in an earlier post, which I believe was missed, so I hope this is not considered a "thread hi-jack."
Now, this may be a dumb question, but I was thinking that the stock, in-cab loader valve could be plumbed up using the FEL's lift, uncurl and recurl circuits for LIFT, LEFT AND RIGHT on the snowplow set-up.
Am I mistaken, or is the third function valve superior for this work in some way I'm missing? Because I would have thought just using the joystick (especially if in an open station machine, with thick gloves, although I do realize the O.P.'s is NOT open) would be easier than trying to use a thumb-operated button.
I look forward to the replies.
My Hoe
I was just at my dealer yesterday, fleshing out details with regard to my L3940 purchase, and am undecided on how to go with respect to third function - so I'm glad you brought this up. This thread has been stagnant lately, so I don't consider it hi-jacking, My Hoe, and since I may be adding the the angle plow later, I would like to hear what anyone has to say on the subject in answer to your question.
I'd also like to hear more details about the problems other Kubota owners have experienced (like nybirdman mentioned) with regard to their third function valving. In another thread, I believe I read that it seems to bleed off hydraulic pressure. (?)
Edited to add another question: Can the W.R.Long set up be added at a later date, in lieu of putting the Kubota third valve on now?
2024 CATERPILLAR 255 SKID STEER (A51246)
2024 CATERPILLAR...
2020 TAKEUCHI TL 12V-2 (A52472)
2020 TAKEUCHI TL...
LOT NUMBER 51 (A53084)
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
1998 C6500 Chevy, 3126 Cat Engine (A52384)
1998 C6500 Chevy...
2021 CASE IH 345 LOT NUMBER 12 (A53084)
2021 CASE IH 345...
