What valve for Ford 4100 loader?
   / What valve for Ford 4100 loader? #1
Pete O
Victoria, Australia
Ford 4100
As I continue the restoration of my Ford 4100 (see this thread ) I'm starting to look at the loader; the 2-spool valve is shot and I want to add a third function to the loader so I can run a grapple (future build project). I haven't been able to find a hydraulic flow figure for the tractor but this is the pump, which has been renewed.
I'm wondering if this valve would be suitable for the purpose? The price is very attractive. The tractor already has the optional diverter valve that selects flow to the 3pl or the loader controls. My experience with hydraulics is very limited so any knowledgeable advice will be much appreciated.
   / What valve for Ford 4100 loader? #2
That valve will do just fine. You may find a valve with similar specs having a joystick for the loader functions and a lever for the third function.
   / What valve for Ford 4100 loader? #3
Check out northern tool also for cheaper valves
   / What valve for Ford 4100 loader? #5
Thanks for the replies. I'm in Australia, I'm envious of the access that you guys in the US have to cheap parts, my experience of shipping of parts like this from somewhere like surplus centre is that it would probably double the price. with this kind of thing i'm limited to what i can find locally.
I have another couple of questions;
would the loader valve on this tractor be 'open centre' or 'closed centre';
also, would a 'power beyond' setup enable me to piggy-back a second control valve to run another set of rams; what I'm contemplating is converting my 3PL grader blade to hydraulic swing and tilt, I'm thinking I could use my old 2-spool loader valve to control the grader blade. If the concept works but the leakage through the worn valve is a hassle, I can look out for a cheap 2-spool valve later on.
KJ 12'x20' Single Garage Metal Shed (A50121)
KJ 12'x20' Single...
Peterbilt 377 Semi-Truck (A52748)
Peterbilt 377...
2012 Cadillac CTS Sedan (A50324)
2012 Cadillac CTS...
2001 Chevrolet 2500 (A50121)
2001 Chevrolet...
Dingo TX427 Mini Skidloader (PARTS) (A50774)
Dingo TX427 Mini...
