What valve do I need?
/ What valve do I need? #1
ParkerFly
In the process of reworking and adding to the hydraulics on a piece of equipment. I need a valve with two spools (to control 2 separate cylinders). Just one that is normally in neutral and you can push or pull to extend or retract the cylinder. No need for float. Can someone give me a suggestion on what I need? Thanks.
/ What valve do I need? #2
Need a little more info first. What is the GPM rating of the machine or pump you are using?
That's been a problem for me trying to find out. It has a belt driven pump off of the motor on it, but no markings or any info on it that I can find that shows what the GPM is. I figured to be on the safe side I should get a valve that will handle higher flows. Based on my experience with other hydraulic equipment and comparing it to the speed at which this system works, my best guess would be that it flows in the high teens at best and in reality probably lower than that.
/ What valve do I need? #5
I'll have to get a measurement on the ports, but best I can recall they are pretty large. I just know it seems slow operating a 4" cylinder when compared to skid loaders with flow in the high teens operating a 4" cylinder.
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
CAT 345CL NEW Track Chains (A68134)
CAT 345CL NEW...
1987 FORD F-350 CUSTOM SERVICE TRUCK (A64280)
1987 FORD F-350...
953D GP Bucket (A68134)
953D GP Bucket...
2020 INTERNATIONAL LT625 SLEEPER (A59910)
2020 INTERNATIONAL...
SARLO (A64557)
SARLO (A64557)
