what type
   / what type #1
cosmic chief
Geelong Australia
eastwind dfm 254 4wd 25hp tractor
i hav a eastwind dfm 254 4wd tractor 25 hp what type of hydraulic oil do i use to top it up with
   / what type #2
have you changed the hyd oil since you got it?
how many hours have you used it?
if it's not new / just serviced I'd change and put in something I'm familair with / can top off with.. like a UTF fluid inthe hyds.
as for the rear and tranny.. check if it wants utf or gear oil.. many like gear oil.
if you don't want to change the oil, and need to top the hyd resv off.. hard to go wrong with utf fluid... should be ok to top off a sump, even if it had a plain hyd oil in it..
soundguy
   / what type #4
Is this a Jinma or Foton tractor re-branded? Does it share a common sump with the gear box for the hydraulics or does it have seperate oil sumps for the gear boxes and hydraulics?
If it has a seperate oil sump for the hydraulics I would use AW32 hydraulic oil. To be sure I would google your tractor type and find a dealer selling them to get a full list of what fluids should be used.
Chris
   / what type #5
imho, UTF fluids are a higher quality oil than a plain AW/ISO hyd oil. and utf should match aw32 viscosity specs pretty closely..
that's just my opinion though..
2015 CHEVROLET C3500 SERVICE TRUCK (A51406)
2015 CHEVROLET...
Set 4- 10-16.5 tires/wheel for bobcat (A53421)
Set 4- 10-16.5...
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
2016 CATERPILLAR 325FL EXCAVATOR (A51246)
2016 CATERPILLAR...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
