Snow Attachments what type of steel for snow plow wear bar / blade?
   / what type of steel for snow plow wear bar / blade? #1
nvr-enuf
Hello everyone - I am in need of replacing my snow blower scraper blade. Does anyone know the specific steel call out / description for the wear bar? High carbon steel is not a description but a general term that the steel supplier can not go off of.
My desire was to buy at a local steel supplier versus buying at a local bucket mfg.
Thanks in advance.
scott
   / what type of steel for snow plow wear bar / blade? #2
I'd be very suprised if a blower blade were anything but regular mild steel.
On a loader they'd use T1, which is hardened hi carbon and hard to drill.
I'd simply buy some regular mild steel flat stock, maybe go a guage thicker if you wish longer life.
I make these remarks simply by observing the wear patterns of the different edge stocks as well as noting that a blower blade primarily only encounters snow vs earth gravel and sand as do loaders.
Ther also would be a major price differance that would seriously increase the cost of a blower.
   / what type of steel for snow plow wear bar / blade? #3
Ditto, not only that but most steel shops won't sell you anything other than a full length. Why not just grab a few hardface rods and run a bead along the edge, probably cheaper.....Mike
   / what type of steel for snow plow wear bar / blade? #4
Use 1044 Bar. It has a high enough carbon content to wear well, but can still be machined.
   / what type of steel for snow plow wear bar / blade? #5
Thanks in advance.
scott
my oppinion you dont need any high carbon steel wount make a differance use crs c1018 grade if u cant find it hrs will also work . i use a piece of uhmw plastic 1in x 6in x6ft it lighter, also i use the plow feet so plastic dosent wear out as quick.
2011 Crown Victoria Sedan (A51694)
2011 Crown...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A52748)
Kubota BX2680...
2018 JLG 3246ES 32FT. Scissor Lift (A51691)
2018 JLG 3246ES...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
