Snow Attachments what type of steel for snow plow wear bar / blade?
   / what type of steel for snow plow wear bar / blade? #1
nvr-enuf
Hello everyone - I am in need of replacing my snow blower scraper blade. Does anyone know the specific steel call out / description for the wear bar? High carbon steel is not a description but a general term that the steel supplier can not go off of.
My desire was to buy at a local steel supplier versus buying at a local bucket mfg.
Thanks in advance.
scott
   / what type of steel for snow plow wear bar / blade? #2
I'd be very suprised if a blower blade were anything but regular mild steel.
On a loader they'd use T1, which is hardened hi carbon and hard to drill.
I'd simply buy some regular mild steel flat stock, maybe go a guage thicker if you wish longer life.
I make these remarks simply by observing the wear patterns of the different edge stocks as well as noting that a blower blade primarily only encounters snow vs earth gravel and sand as do loaders.
Ther also would be a major price differance that would seriously increase the cost of a blower.
   / what type of steel for snow plow wear bar / blade? #3
Ditto, not only that but most steel shops won't sell you anything other than a full length. Why not just grab a few hardface rods and run a bead along the edge, probably cheaper.....Mike
   / what type of steel for snow plow wear bar / blade? #4
Use 1044 Bar. It has a high enough carbon content to wear well, but can still be machined.
   / what type of steel for snow plow wear bar / blade? #5
Thanks in advance.
scott
my oppinion you dont need any high carbon steel wount make a differance use crs c1018 grade if u cant find it hrs will also work . i use a piece of uhmw plastic 1in x 6in x6ft it lighter, also i use the plow feet so plastic dosent wear out as quick.
2021 PETERBILT 389 MID-ROOF SLEEPER (A52472)
2021 PETERBILT 389...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2006 UTILITY VS2RA 53 FT REEFER TRAILER (A52577)
2006 UTILITY VS2RA...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2023 Globe Booster Flipaxle (A51572)
2023 Globe Booster...
