Backhoe What type of Root Grapple to Purchase 66" or 72"?
   / What type of Root Grapple to Purchase 66" or 72"? #1
Eddieman555
Grafton Ontario Canada
Kubota L4400
I have a Kubota L4400 and I am interested in purchasing a Root Grapple to help me with Roots and remove Debris. I was looking at a Anbo Root Grapple m (for compact tractors).....but they (Anbo) were trying to push me to a a S Grapple instead? I am concerned that the S is a little to big for the L4400.
I do not know whether to purchase a 66" or 72" size grapple as well? Does anyone have suggestions?
   / What type of Root Grapple to Purchase 66" or 72"? #2
You can get too big... the problem is the wider you go you can tweak your loader arms... you'll likely be just right around 66"... KennyV
   / What type of Root Grapple to Purchase 66" or 72"? #3
I have a 66" Anbo grapple and it is a beast and light weight. The model I have is the GRM series. This unit weighs less than 400# and is really tough. Did I mention I have it on a L4400 Kubota?
I have the 6 inch spacing on mine and it overall is a perfect match.
Here are a couple links to some of the grapple work.
Anbo Grapple 1
Anbo Grapple 2
   / What type of Root Grapple to Purchase 66" or 72"? #4
dex3361,
I bought a different brand from Skid Steer Attachments Pallet Forks Hay Spears Bobcat Cat John Deere Mount Plate and picked the 60" instead of the 72". Weight was a concern as was having it to wide to slip in between trees. The Anbo unit is a high quality product and you won't be disappointed. My unit weighs about 550 lbs and works good for what I need it to do. I cleared a piece of my property this summer and had quite a pile of logs to clean up. Since then, I've used it for moving large rocks, stumps, and clean up of road I have that goes to the back of the property. It's turned into a real handy tool.
   / What type of Root Grapple to Purchase 66" or 72"? #5
Smaller the better.
   / What type of Root Grapple to Purchase 66" or 72"? #6
dex3361,
Nice looking grapple they will spoil you when it comes to lifting stuff.
Vivohome Single Stage Vacuum Pump, Model VB150, 1/3 HP, 110 Volt, Vivohome Gage Set (A59076)
Vivohome Single...
2015 Jeep Compass SUV (A56859)
2015 Jeep Compass...
New/Unused IRGC40 Mini Golf Cart (A57453)
New/Unused IRGC40...
2015 International Durastar 4300 SBA 4 x 2 Water Truck, VIN: 3HAMMMMN4FL510006, Cummins Turbo Die... (A59076)
2015 International...
1969 Lincoln Continental Mark III (A56857)
1969 Lincoln...
Wagon Wheel Rocking Chairs (A55758)
Wagon Wheel...
