Front-End Loader What type of QA is this
   / What type of QA is this #1
Dezlsmkr7127
international
   / What type of QA is this #2
Looks very similar to the Euro style QA.
It does but the lower pin boss’s are the same distance apart as the top hooks. I thought standard euro was sit inward?
   / What type of QA is this #4
There are some varieties inside the Euro style though.
Here is a couple of them:
I measured mine it’s 50” center to center which would be like 1270 mm so it doesn’t appear to match any of those dimensions. Unless I’m not reading that correctly
   / What type of QA is this #6
Maybe a custom application of some sort? I don't know. When I built my loader, I tried to go with the Euro dimensions but then changed at the end, because it would be just too high. I still maintained the width though.
Is that a loader for a tractor? Have you tried going by the brand name?
Yes it a tractor loader. It has HLA pallet forks and the standard bucket. Both the tas loader and the company HLA appear to be from Canada.
Yes that does. Further research it appears the loader is a Frey. I am seeing mention of the Frey style QA so maybe I’m on the right path
So the best I can figure is it is a Branson QA however on worksaver website the measurements between top pin and bottom pin do not go with mine. I’m roughly 9” from center to center but it looks exactly like the Branson
New in Crate 20' x 40' Hoop Building (A50515)
New in Crate 20' x...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
2017 E-Z Beever M12R Towable Brush Chipper (A50322)
2017 E-Z Beever...
2019 Dodge Journey GT SUV (A50324)
2019 Dodge Journey...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51244)
(2) METAL SPOOLS...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2013 Ford F-150...
