What type of knot do you use to tie your twine rolls together?
   / What type of knot do you use to tie your twine rolls together? #1
tmac196
Temperance, MI
1951 Ford 8N, 1965 Ford 2000, Grasshopper 325D, JD 5065M
My baler's (NH 565) operator's manual and the package containing the twine are surprisingly silent on the issue.
The previous owner (of the baler) used a knot identical to the knot tied by the knotters on the baler and my neighbor suggests that based upon his experience a square knot with the loose twine ends tacked down with electrical tape works best...hmmm.
Does it even matter?
Your opinions, please.
   / What type of knot do you use to tie your twine rolls together? #2
I use a square knot (no tape), works fine on our Hayliner 273.
Aaron Z
   / What type of knot do you use to tie your twine rolls together? #3
My NH 65 baler manual says to use a square knot
   / What type of knot do you use to tie your twine rolls together? #4
same as above, but may I add that I also keep a wire cutters in the twine box to trim back the ends of the knot to about 1/4" to eliminate the chances of hang-ups in the needles and billhooks. This also looks better to a customer buying bales and (as usual) always asking "what happened to 'that bale' ".
   / What type of knot do you use to tie your twine rolls together? #5
Always used a square knot with the ends trimmed.
Got it. A square knot it is. Thank you all.
   / What type of knot do you use to tie your twine rolls together? #7
Grandfather taught me to use a square knot and roll the finished knot between my palms, then pull it tight again. Trim ends. Zero problems.
   / What type of knot do you use to tie your twine rolls together? #8
I tie the same kind of knot the baler does and trim the ends down to about 1/4". Never had a problem doing it that way.
   / What type of knot do you use to tie your twine rolls together? #9
I use a weavers knot.
   / What type of knot do you use to tie your twine rolls together? #10
I use the same
Rears 1000 Gallon Orchard Sprayer (A50120)
Rears 1000 Gallon...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
2013 Hyundai Sonata Sedan (A50324)
2013 Hyundai...
2016 Ford Explorer...
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
2008 Volkswagen Eos Convertible (A50324)
2008 Volkswagen...
