What type of JD grease do you use?
   / What type of JD grease do you use? #21
JD parts online list it for $2.69 per tube.
   / What type of JD grease do you use? #22
zuiko said:
What is the price on the green JD polyurea grease?
I have been using the JD Polyura grease since I bought my machine, it's what the local dealer recomends and stocks on the shelf.
I just bought 2 new tubes this past Saturday at $2.69 per tube.
   / What type of JD grease do you use? #23
After passing up lithium grease at TSC and a few other stores, I visited my local JD dealer to get the green polyurea grease that my FEL is craving. And they were out! Not only that, but the parts guy told me to use the JD lithium grease instead, which he did have in stock. I think he was being honest about his belief in what's best, but I wonder if it's based on any real expertise. Since my FEL was due for greasing, I did buy the pink JD lithium grease and squirted some into the FEL fittings... but I am wondering if the green polyurea is really what I need. Also wondering about incompatibility since the factory grease is supposed to be polyurea - seems that JD says it is compatible and all other sources say it is NOT compatible with lithium grease. Anyone?
   / What type of JD grease do you use? #24
I use this JD SD Polyurea grease on everything, seems to work out ok:
Multi-Purpose SD Polyurea Grease (TY6341, CXTY24420, TY24421, TY24422, CXTY24419, CXTY6341, CXTY24421, CXTY24422)
Applications
· Ideal in rolling-contact applications
· -15 to 350 degrees F (-26 to 177 degrees C)
· For high-temperature, extreme-pressure conditions
· Used for initial lubrication at the factory in U-joints and axle bearings
· For excellent protection in corrosive and wet conditions
· Compatible with most other types of grease
· Excellent for all-purpose applications, especially those requiring a severe-duty grease
· Our best multi-purpose grease
Service rating
· Equipment manufacturers' extended service intervals
· NLGI grade 2
· JDM J13E1, J13E4, J13E5 and J25C
· GC-LB
Physical properties
· Green color (emerald)
· Polyurea thickened
· Paraffinic-base oil with EP and anti-rust additives
First Products Fertilizer Spreader (A53314)
First Products...
Mini Excavator Rake (A53316)
Mini Excavator...
2019 Chevrolet Silverado 3500HD 4x4 Crew Cab 10FT Flatbed Truck (A51692)
2019 Chevrolet...
Giyi 72" Mulcher (A53316)
Giyi 72" Mulcher...
Kennco Row Mower (A53316)
Kennco Row Mower...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
