What type of hydraulic quick connect for FEL on BX24
   / What type of hydraulic quick connect for FEL on BX24
Since you guys are probably right next to your machines (mine is a couple of miles away), I will take you at your word that the fittings are all the same. Having said that though, if you would have asked me before, I would have bet big money that the BH hoses were larger than the FEL hoses.
   / What type of hydraulic quick connect for FEL on BX24 #12
bx24 said:
... I will take you at your word that the fittings are all the same. Having said that though, if you would have asked me before, I would have bet big money that the BH hoses were larger than the FEL hoses.
It is difficult to read the part number on these couplers to determine their actual size. An easier way to tell what size they are is to measure the length of the coupler itself. For example, the 1/4 in. Snap-Tite coupler (which is the one used the the FEL and BH of the BX24) is actually 2 1/4 inches long. On the other hand, the 3/8 in. Snap-Tite coupler is 2 1/2 inches long.
   / What type of hydraulic quick connect for FEL on BX24 #13
The BX24 does use a combination of 1/4" and 3/8" hose (on both the FEL loader and BH). The hose fittting's on the 3/8 hose are reduced to 1/4" NPT. All the QD's are 1/4".
I bought the the fittings I linked to earlier and used them on the front as well as the rear (checking htdraulic PSI). The QD's are same same-1/4"
   / What type of hydraulic quick connect for FEL on BX24 #14
Also, FWIW, you can buy the couplers directly from Snap Tite, which is what I do.
snap tite couplers
Just pull the part number off of the part(s) on your tractor. It also tells you on the site which partnumber mates to the part you are looking at.
Mike
Great info, thanks guys
(10) 8' Treated Posts (A50515)
(10) 8' Treated...
2013 Nissan Sentra (A50324)
2013 Nissan Sentra...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2017 FREIGHTLINER...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
2018 WACKER NEUSON RD28 120 DOUBLE DRUM ROLLER (A51242)
2018 WACKER NEUSON...
90018 (A48082)
90018 (A48082)
