What type of hose for Diesel Fuel?
   / What type of hose for Diesel Fuel? #1
jenrow33
Michigan
Kubota L3400HST
Hi guys. I have a barrel pump that I use to store fuel and have been pumping into a 5 gallon can when I need to fill the tractor. I'd like to set up about a 15 foot hose with a ball valve on the end so I can fill the tractor directly from the barrel. What type of hose do I need?
Thanks!
   / What type of hose for Diesel Fuel? #2
Check with Harbor Freight, at one time they carried just what your describing.
   / What type of hose for Diesel Fuel? #3
Thanks!
If you have a Tractor Supply close, check their on-line catalog. I purchased a replacement hose for my elevated gravity flow tank there a few years ago.
Stock item.
   / What type of hose for Diesel Fuel? #4
Thanks!
I bought Fuel line hose at the auto parts store.
   / What type of hose for Diesel Fuel? #5
LB,
Marietta is south of Canton by 100 miles if that's what you mean.:thumbsup:
   / What type of hose for Diesel Fuel? #6
Stock item.
I also bought a gas station type hose and nozzle there for my electric fuel pump.
   / What type of hose for Diesel Fuel? #7
tsc, HF, and most better auto places have either bulk hoses or packaged hoses and valves for fuel stations.
i know our local tsc and napa does.. etc.
   / What type of hose for Diesel Fuel? #9
Gas pump/fuel pump hose is crazy expensive because it has grounding wires inside of it for gasoline. And, it's designed to be treated by idiots at gas stations, so it can get run over by all sorts of things, dragged down streets, weather, etc. etc.
For your own, diesel tank anything that's rated for petroleum products will work. Heck, I've even seen garden hoses.
But, with an elevated tank - keep your eye on dry rotting in the line. Next thing you know, everything in the elevated tank, might end up in your yard.
   / What type of hose for Diesel Fuel? #10
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/nerve-alive-supplement-reviews-inspired-by-nervecalm-for-natural-nerv-1044754
https://www.accessn...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A51219)
2016 INTERNATIONAL...
2017 Caterpillar 326FL Hydraulic Excavator (A50322)
2017 Caterpillar...
2015 CATERPILLAR 305E2 CR EXCAVATOR (A51242)
2015 CATERPILLAR...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
