• Thank you for participating in the Summit Tractors Community. Per special arrangement with the TBN team, Summit Tractors will regularly monitor and contribute to this forum to help ensure that the community has direct access to Summit. You can ask and find answers to a range of topics directly from Summit and from other TBN users, including; Where to Buy, Future Retailers and Locations, Financing, Compatible Equipment, Tractor Operating, Equipment Specifications, Parts & Service Support, Warranty and anything else that may assist those in the market for a new tractor. If you cannot find the answer to a specific question on this forum, please feel free to contact Summit Tractors Directly or through a Private Message to Summit Tractors Support via TBN.
Ad top of page
What type of grease should I use on my tx 25?
   / What type of grease should I use on my tx 25? #1
Mikehe
Summit tx 25
what type of grease should I use on my tx 25 I am in NH
   / What type of grease should I use on my tx 25? #3
I’ve been using AirTec Li400 from AET Systems for the last year.
   / What type of grease should I use on my tx 25? #4
I use the Lucas green heavy duty polyurea grease. It’s a few bucks more per tube, but really holds in place without washing out.
   / What type of grease should I use on my tx 25? #5
The grease type will vary by what it's lubricating. If you are lubrication sleeve bearings for a sliding surface like loader pivots the above suggestions are good and if the grease has molybdenum disulfide in it that's even better - or you can add it. If lubricating a roller or ball bearing you do not want molybdenum disulfide in your grease as it makes the grease too slick and the bearings can slide instead of rotate.
   / What type of grease should I use on my tx 25? #6
Not trying to be obtuse about a grease type but merely giving my take on things. In some specific instances, there can be lubricants recommended for the needs of movable joint or bearing of some sort. If there are due to high pressure or speed or other extenuating circumstance, go with what is recommended by the OEM.
In the case of a typical tractor, any grease is preferable to no grease. I have personally witnessed several failed bearing, movable joints or similar due to lack of lubrication but none due to the wrong type of grease. My experience runs to commercial construction equipment mostly but I am pretty sure the same applies to almost all tractors. Get whatever grease is handy, cheap and plentiful. Use it often and if in doubt, a few extra pumps of grease usually isn't a bad thing.
BTTL15H-6 Excavator (A49251)
BTTL15H-6...
3pt Rototiller (A49251)
3pt Rototiller...
1999 HydraMac 2650D Skidloader (A49251)
1999 HydraMac...
Pair of Tractor Tires on Rims (A47164)
Pair of Tractor...
2016 VOLVO VNL780 SLEEPER (A45679)
2016 VOLVO VNL780...
82" Pallet Fork Extensions, New (A47371)
82" Pallet Fork...
Ad bottom of page
