• Thank you for participating in the Summit Tractors Community. Per special arrangement with the TBN team, Summit Tractors will regularly monitor and contribute to this forum to help ensure that the community has direct access to Summit. You can ask and find answers to a range of topics directly from Summit and from other TBN users. The Summit Tractors brand is here to stay with the recent acquisition of the Summit Tractors brand by ITL, the 5th largest tractor manufacturer in the world. Yes, we make our own tractors, something very important for our owners and prospective owner to know. Summit’s founder continues to lead operations and the U.S. team that supports our retailers, tractor owners and TBN users.
Ad top of page
What type of grease should I use on my tx 25?
   / What type of grease should I use on my tx 25? #1
Mikehe
Summit tx 25
what type of grease should I use on my tx 25 I am in NH
   / What type of grease should I use on my tx 25? #3
I’ve been using AirTec Li400 from AET Systems for the last year.
   / What type of grease should I use on my tx 25? #4
I use the Lucas green heavy duty polyurea grease. It’s a few bucks more per tube, but really holds in place without washing out.
   / What type of grease should I use on my tx 25? #5
The grease type will vary by what it's lubricating. If you are lubrication sleeve bearings for a sliding surface like loader pivots the above suggestions are good and if the grease has molybdenum disulfide in it that's even better - or you can add it. If lubricating a roller or ball bearing you do not want molybdenum disulfide in your grease as it makes the grease too slick and the bearings can slide instead of rotate.
   / What type of grease should I use on my tx 25? #6
Not trying to be obtuse about a grease type but merely giving my take on things. In some specific instances, there can be lubricants recommended for the needs of movable joint or bearing of some sort. If there are due to high pressure or speed or other extenuating circumstance, go with what is recommended by the OEM.
In the case of a typical tractor, any grease is preferable to no grease. I have personally witnessed several failed bearing, movable joints or similar due to lack of lubrication but none due to the wrong type of grease. My experience runs to commercial construction equipment mostly but I am pretty sure the same applies to almost all tractors. Get whatever grease is handy, cheap and plentiful. Use it often and if in doubt, a few extra pumps of grease usually isn't a bad thing.
2018 Kubota U17 (A53317)
2018 Kubota U17...
2005 JOHN DEERE 317 SKID STEER (A52709)
2005 JOHN DEERE...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1EF7EKF89312 (A57453)
2014 Ford F-150...
2015 Chevrolet Silverado 2500 4x4 Crew Cab Pickup Truck (A56858)
2015 Chevrolet...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
SDLD25 MINI DUMPER (A58214)
SDLD25 MINI DUMPER...
Ad bottom of page
