What type of gas motor mf 165?
   / What type of gas motor mf 165? #1
desert trader
Shoshone,Idaho
Massey Ferguson 165
How do you tell the difference between a perkins gas and continentel engine
on a mf 165. Also how can you clean the hydraulic filter when there is no acess port and the left side plate is where the auxilery hydraulics is hooked to so you can't get to the filter as described in the manual.
   / What type of gas motor mf 165? #2
I could tell by looking, but I can't tell you really how to tell if that makes any sense? Look at the online parts books and see if you can tell the differences in parts like the water pump, distributor and such. If there's no tag on it of course.
You may be able to take the right side cover off to get to the filter?
   / What type of gas motor mf 165? #3
;)There's also a filter just in front of the rad, near the top right hand corner. Its a small washable filter.Not sure if your's will have it as it's on Multi-power tractors.As for the internal filter in the trans,I think its a big job to do,I had to pull the seat and the rock shaft cover,in order to access the filter screen. Its a washable screen also. Mines a MF 175 but pretty sure the MF 165 is the same.Larry:D
UNUSED AGT ATK-B1000 2 POST HYD CAR LIFT (A51244)
UNUSED AGT...
2022 John Deere S780 Combine (A50657)
2022 John Deere...
2023 JOHN DEERE 30G EXCAVATOR (A51242)
2023 JOHN DEERE...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A52128)
Ditch Witch 6510A...
Wolverine Quick Attach Tree Spade (A50514)
Wolverine Quick...
Root Grapple (A50322)
