What Type of Engine Heater??
   / What Type of Engine Heater?? #21
You're adding heat to a large metal conductive object. It will radiate that energy to the surrounding air at a rate based on it's surface area, and the temperature of the surrounding air (and the specific heat of that air, but let's not complicate things).
Air is a good insulator as long as the warmed air is not being stripped away and replaced with other cold air (i.e. wind or a draft). The point being: Anything that gets tractor out of wind, even a tarp, will improve block and oil pan heating. Perhaps only by a couple degrees versus not having one, depending on wind. So maybe not a big difference when air temps can vary more than any improvement, but every degree can help.
I am strongly against anything that increases the number of heat/cool cycles. (Thermal expansion, then contraction, repeated again and again for days and weeks.) I try to start up and shut off my tractor as few times as possible. Even in the summer. IMHO, like an airplane: sometimes it's not the miles or hours flown, it the number of times its been cycled!
Same for thermal cycles when metal on metal (& usually a gasket is involved) is expanding and contracting. Sometimes at different rates. This causes wear!
Yes, actual wear is...uhm...actual wear (!), but so is multiple cycling with little actual wear.
Example: Would you rather by a car with 100,000 miles, but driven 1000 miles at a time, or a 50,000 mile car driven 5 miles at a time?
Unfortunately most equipment doesn't come with cycle meters (counters) so we'd buy the 50,000 mile one for a higher price.
Ratchet Straps (A59230)
Ratchet Straps...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
HITACHI EX550LC EXCAVATOR (A58214)
HITACHI EX550LC...
2019 John Deere 310L EP Backhoe (A53485)
2019 John Deere...
More info coming soon! (A56858)
More info coming...
