What type of brake controller to buy?
   / What type of brake controller to buy? #1
T185
JD 2520 & JD 3039R
Is there a big difference between the proportional and the time delayed brake controller systems? I will be using my trailer about a twenty times a year to move my tractor haul lumber etc. Any one brand that I need to stay away from?
Thanks
   / What type of brake controller to buy? #2
I just purchased a Prodigy 3 it is awsome, well worth the money. I shopped the local supply places, nobody had one .
Ended up purchasing from Auto Accessories out of OHIO,$127.00 2 day ship. You can buya spare harness for multiple vehicles plus see if your trailer brakes our working with the cool display.
Macdabs
   / What type of brake controller to buy? #3
Mine is a prius. works great.
   / What type of brake controller to buy? #4
I have a Reece tow power in one truck and the other 2 trucks have the Ford factory trailer brake controller. The Reece is ok, but no prodigy. The Ford factory is by far the best I have used in my 20 years of pulling.
Chris
   / What type of brake controller to buy? #5
TheTekonsha Prodigy is the best brake controller I have ever used. A few friends haul gooseneck campers and trailers with them and the auto adjustability is great.
   / What type of brake controller to buy? #6
Thanks
Without being specific to a brand, the proportional by design is a much better system. The time delayed can best be described as an uneducated guess under most normal braking situations. Sorry if that sounded like it came from a lawyers mouth!
A brake controler is one area where I would not skimp a dime. I have a Tekonsha Voyager, or how ever it's spelled, but should upgrade to a Prodigy. I think I made a mistake when I took it out of the truck I traded..... I could have left it in there and told my wife I needed a new one!!
From how I understand it, the time delay doesn't really look at the deceleration rate of the tow vehicle and in a panic stop, can leave you in for a wild ride!
There is another brand that I can not think of that is actually cable operated from the brake pedal. I've heard this is the best model out there but very expensive and can't go from vehicle to vehicle easily.
I can not speak form first hand experiece, but my next controller WILL BE a Prodigy!
I will only add that for 20 times a year, I'd get a good one!
Ken
   / What type of brake controller to buy? #7
Did a quick look on the Tekonsha site and it seems they now have a model higher that the Prodigy. Now they have a P3 out that is supposed to be an updated version of the Prodigy...............
You can set it up for three different languages but english would be just fine for me.
Wonder in what other ways it is "better" than the standard Prodigy??
Ken
   / What type of brake controller to buy? #8
I currently own a prodigy and love it. Before this one I had a time based unit. I hated the timed unit because if you set the gain level to the proper level, the trailer brakes would be stop you too soon even with very light pressure on the brake pedal. The trailer brakes would work anytime the brake lights came on. Too often the light would turn yellow and I would want to make a smooth approach to the light but would have to pulse my brakes so that I wouldn't stop too soon. It would feel like I got rear ended everytime I let my foot off the brakes as the trailer brakes immediately shut off. The only solution was to back off the gain but then in an emergency, your trailer brakes were set to a reduced level. Not an option for me. Spring for the prodigy or the newer model and feel good knowing that you have the safest braking system unless you want to build up your neck muscles from the constant whiplash :).
   / What type of brake controller to buy? #9
I have the Tekonsha P3 and it is just awesome. Can't say enough good things about it, and like MACDABS, I got mine for the same deal at Automotive Accessories.
-Jeff
2011 GMC Sierra 4x4 Pickup Truck, VIN # 3GTP2WE36BG213306 (A51572)
2011 GMC Sierra...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2015 INTERNATIONAL MA025 (A52472)
2015 INTERNATIONAL...
John Deere 6120E (A50323)
John Deere 6120E...
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
