What type hydraulic fluid in a Gehl 4500?
   / What type hydraulic fluid in a Gehl 4500? #1
Jim 1944
Ohio outside Cincinnati
Ford/New Holland 1520
I had a few hoses (5 to be exact) burn and after I replaced them I can't get the bucket to return after dumping. The fluid looks like red tranny fluid and I'm guessing type "F" ford but don't want to add anything until I know what I need to use. This is a 1979 Gehl 4500 and I finally found the owner/operator manual but haven't received it yet; mine is on back order.. I don't have anything showing on the dipstick and figure that is the source of my issues. I did find out one thing. Don't get a used skid steer on a hill without checking out the gas tank to see if it leaks.:ashamed: After mine stalled it leaked on top of the starter and when I cranked it I saw a pretty blaze as I bailed. Could have been serious but wasn't; just a big mess for me to repair. :( Another question is do I have to bleed the tilt cylinder after I fill up the tank with fluid? I think it should force fluid thu and more or less bleed itself, am I correct. I'm an old car buff but new to this type of equipment. I did install all new hoses to replace those burned.
   / What type hydraulic fluid in a Gehl 4500? #2
OOOOH! That sucks. It will bleed out on its own. If you are getting fluid from a farm store, check on jugs for an 800 number. I have done that with cenex products before and they were pretty helpful in determining what I needed.
If you have QD's (quick disconnects) maybe unhook and rehook afew times to make sure they are seated right.
   / What type hydraulic fluid in a Gehl 4500? #3
They do take hydraulic fluid not type F!!!!
   / What type hydraulic fluid in a Gehl 4500? #4
My case trencher, says to use either ATF, or Hy-Trans. . Our Power-Tracs, use 10W-40 motor oil, and they have used that or similar for about 20 years.
Case 1845c skidsteer also uses 10W-40 with a qt of Case additive, or Hy-Trans.
   / What type hydraulic fluid in a Gehl 4500? #5
On the bucket not returning, you might need to take the valve apart and clean debris/crud from the burnt hoses.
Thanks for the replies. I did have an older Case-Davis trencher with a backhoe attachment as well as the blade to push dirt. The factory manual did say to use type "F" tranny fluid. I'm always in the dark without a manual but I do know that I can buy Hydraulic fluid ($47.00 per 5 gallons where I had new hoses made) a lot cheaper than the tranny fluid about 4 bucks a quart. The fluid that sprayed me was a pretty red stream and did smell like used transmission fluid. Matter of fact I'm a proud owner of a now pink t-shirt but the slick hair is gone. Wife said it would mess-up the pillows. :laughing: I'm hoping a Gehl owner can enlighten me if he had the same model. I do have a manual for a Gehl 4525/4625v which says use Mobil DTE 15M or equivalent which is not tranny fluid. I always get in trouble when I buy something cheap. Seems I generally get it completely fixed for more than it would have cost if no repairs were needed. But I love to tinker and life is always a learning curve. My plans are to flush the system and replace the filter as I think everything is probably contaminated from when the hoses were burning. I'll try some of the suggestions and the 1-800 number will be number 1 on my list. Thanks Guys.
2008 Chevrolet Malibu Sedan (A51694)
2008 Chevrolet...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
TOYOTA 7FGCU25 LP SIT DOWN FORKLIFT (A52472)
TOYOTA 7FGCU25 LP...
2018 Caterpillar CS54B Smooth Drum Vibratory Dirt Compactor (A51691)
2018 Caterpillar...
JOHN DEERE 54D LOT NUMBER 162 (A53084)
JOHN DEERE 54D LOT...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
