What two Landpride attachments with new Kubota purchase?
   / What two Landpride attachments with new Kubota purchase? #1
Lucky_Ducky
MX6000 w/ cab
What two Landpride attachments would you get with a new MX6000 purchase?
Assume this is your first tractor and have no other attachments. I understand everyone’s needs are different, but I want to see what you would get first.
   / What two Landpride attachments with new Kubota purchase? #2
Pallet forks and rear snow blade.
   / What two Landpride attachments with new Kubota purchase? #5
Pallet forks and box blade or scrape blade.
   / What two Landpride attachments with new Kubota purchase? #6
Grapple and land plane
   / What two Landpride attachments with new Kubota purchase? #7
The LandPride RB37 back blade has swinging offset in 3 widths. I find that offset feature to be real useful. Also get it with end caps and skid shoes.. If there is any budget remaining, add hydraulics.
Second implement would be their rock bucket.
But those are for what I do with the tractor...mostly landscaping in the high desert. Others have different uses entirely.
rScotty
   / What two Landpride attachments with new Kubota purchase? #8
Bush Hog and an All Purpose Plow / Field Cultivator.
   / What two Landpride attachments with new Kubota purchase? #9
Only 2 implements ? That's like limiting yourself to just 1 girlfriend :p
Maybe you could do with a smaller tractor and more implements ?
Plus you didn't tell how the tractor would be used... that alone will tell you what you need.
You gonna Mow? You will need a mower
Gonna build a road? You may need a Land plane
Gonna clear land? You may need a grapple
Gonna create a building pad? You will want a box blade.
I'm assuming you have a FEL and bucket?
   / What two Landpride attachments with new Kubota purchase? #10
My first implements. HD bucket for the FEL and a HD rear blade. I have to agree with scootr. These two are only the beginning of a substantial purchase of implements. Wallensteing PTO chipper - Pittsburg moldboard plow - LPGS - ROBB - FEL mounted grapple. I have NO NEED for either a brush hog or back hoe.
And strictly for my comfort - a roll bar mounted cap. Keeps the blazing sun off the chrome dome.
POLY TOTE W/ METAL CAGE & PALLET (A52708)
POLY TOTE W/ METAL...
New/Unused CFG Industrial QK18R Mini Excavator (A57453)
New/Unused CFG...
2012 Ford F-150 Harley-Davidson Edition - 48k miles (A56435)
2012 Ford F-150...
2018 Bomag BW120 SL Tandem Vibratory Smooth Drum Roller (A56857)
2018 Bomag BW120...
2011 WABASH 53 FT DRY VAN (A58018)
2011 WABASH 53 FT...
INOP/NON-RUNNING 1999 Isuzu NPR-HD Cab and Chassis Truck, VIN # 4KLC4B1R5XJ001370 (A57453)
INOP/NON-RUNNING...
