Bama67
Actually, I lied in the title, I want to turbo a Bobcat CT440 but it is exactly the same as a DK40SE.
I am thinking of buying my Bobcat CT440 back from the friend I sold it to a year ago. The problem is I have since moved from 300' above sea level to about 8,500' in the mountains of CO, and using it up to 10,000'
So right off the bat at, this altitude I'm losing 30% power so my 41hp tractor become 29hp. I know the turbo would give me all the power back as the turbo doesn't care about altitude.
By doing a bit of research I found that my Bobcat and DK40 use the Daedong 4A200 engine, and the DK50 uses the exact engine but with a turbo (4A200T) the compression is even the same
I found the exhaust manifold online for about $100, but the turbo is like $2000!
Can someone give me the manufacturer, or model #, or size of this turbo so I can look for other options? I can't find anything on the turbo itself.
Thanks! I think this could be fun project and it is essentially plug and play; and yes I will sort out the oil cooling for the turbo and will add EGT temp gauge to keep tabs on the temps.
