What Tractor?
/ What Tractor? #1
11AcreL
NC
Kubota B2630
I have 11 Acres, 4 acres to be mowed, 1 acre to be bush hogged, 6 acres are trees that will be left alone. I would like to be able to tackle any job that comes up. I was looking at the B7510HSD. Any tractor choice ideas about my situation would be appreciated?
Thanks.
/ What Tractor? #2
Basically you are working 5 acres, and most of that will be mowing. I'd say you are on target with either a 7510 or a 7610. I would prefer the slightly larger 7610 due to its added PTO horsepower, it will handle a slightly larger deck better. But either tractor would fit your needs nicely. Both are considered light tractors, which is a major asset for lawn mowing.
/ What Tractor? #3
Welcome to TBN. /forums/images/graemlins/smile.gif
<font color="blue"> I would like to be able to tackle any job that comes up. </font>
I would want the largest tractor and mower that I could get to mow 4 acres. In the <font color="orange"> Kubota </font> line that would be the B7800 and B26-3030. All three will allow a 72" MMM. These tractors will give you the ability to tackle those unknown project that require more power, height and lift capabilities. Both of these tractors will also let you put a 7 1/2' BH on them.
I have a B2910, replaced by the B3030. There are many times I wish have I had more power, lift height, and lift weight. But the most limiting factor in my search for a tractor was weight for lawn mowing.
/ What Tractor?
Yes, the majority would be mowing.
More information on my plans for the 5 acres; First of all , it is all flat, I will be planting a .5 acre garden, adding 1 horse, adding trees. I would also like to clear a 3' or 4' path through/around the 6 acres of trees.
Thanks Again.
/ What Tractor? #5
Ron makes some really good points about the added size/power. We all wish we had MORE at some times.
As for making 3' to 4' paths through the woods, I think you will be making them more like 6' wide instead. A tractor, even a small one, is going to be about 4' wide. You will need some wiggle room on either side. So if you want to run a small tractor down the path, you will be looking for a wider path. My paths are probably 6' to 8' wide where I run my tractors, I don't have a lot paths, just what I need to get from the ridge tops down to the bottom; they are wider in turns are narrower in straight areas.
/ What Tractor? #6
I just went through the same senario..have 10 acres,need to mow etc.etc..I ended up buying the b7510. There was $1000 difference between the b7510 and b7610 and I just couldn't justify that amount for 2pto hp. I used the money to buy implements that I need /forums/images/graemlins/smile.gif. As for the performance, it has exceeded my expectations,no problem at all with a 48in box blade full of dirt,using 3pth forks to move pallets of firewood, and lugging tree lenghth hwd around. I met a fellow worker who has the b7500 and he told me he snowblows with a 60 inch snowblower no problem whatsoever. To me, the only sacrafice between the 7510 and 7610 would be a 72inch finish mower on 7610 and a 60 inch on the 7510, other than that the recommended implements appeared to me to be the same. The loader on the 7610 has 100lbs more lift..mine 7510 (l-302 loader) lifts a full bucket of rocks,dirt,firewood without much effort at all(I did fill rear tires) so I am happy with it's performance. For my general landscaping,snow,wood,trail,budget needs the b7510 has met my expectations. /forums/images/graemlins/grin.gif
/ What Tractor?
Good information. Thanks.
For price purposes, I think the 7510 is closer to the $100 I really want to spend on a tractor. I don't think they make one for that price yet...
So,
What is a good price for a B7510HSD?
What is a good price for a B2630HSD?
Thanks.
/ What Tractor? #8
local prices here were 7510w/loader..$12,900 wo tax......$13,900 w 60inch mmm wo tax. 7610 is $1000 more for tractor and loader,not sure w/mmm
/ What Tractor?
Bought a B2630 after looking at them up close. It should be delivered today.
Frontier RT3062 (A64126)
Frontier RT3062...
2001 CAT 725 6x6 Water Wagon (A62679)
2001 CAT 725 6x6...
2018 Ford F250 4x4 Ext. Cab Pickup Truck (A64194)
2018 Ford F250 4x4...
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A63688)
2024 Kubota...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
CHAIN LINK FENCE (A64281)
CHAIN LINK FENCE...
