Buying Advice What tractor to buy for general utility work - <50 Acres??
   / What tractor to buy for general utility work - <50 Acres?? #21
Dear Luddites,
Clutches are a time-bomb. Unless someone is giving you a free gear tractor, or you are awash in a nostalgic love affair with gear tractors and doing everything the harder way, the OP should be driven toward a hydro transmission for the lower maintenance costs, and ease of use. Can you imagine using a gear transmission on a zero-turn, a skid loader, or an excavator? Then why do people think a gear transmission is ideal for loader work? despite several posters examples (all given without type of use), a dry clutch on a non-hydro tractor is a $3,000 - $4,000 ticking time-bomb for maintenance. Of course how long a clutch lasts is dependent upon the operator habits more than anything, but if it's used on a loader tractor, then the owner will need to replace their clutch eventually no matter how gently the clutch is babied.
Luddite and proud, thank you. I would rather split my machine and change the clutch 10 times than get into the internals of the hydro once. JMHO
Sent from my LGL35G using TractorByNet
   / What tractor to buy for general utility work - <50 Acres?? #22
Dear Luddites,
I have a MF 1533 gear, use it for everything from mowing, grading driveway, plowing/disking garden to skidding logs outta the woods. You refer to clutch tractors as time bombs, but I had a hydraulic line split on mine in the woods. I was able to drive the tractor out, but if it would've been an HST I would've been dead in the water. So HST's aren't the end all be all greatest thing to happen to tractors ever. And when it comes to ground engaging implements everybody knows gear tractors are way better, mowing and loader work HST's are handier, but with a shuttle shift its no problem to push the clutch in. Really depends on the OP's preference, but for me there was no decision, gear.
   / What tractor to buy for general utility work - <50 Acres?? #23
No need. The hydro will likely not fail.
FWIW, OP this Massey Ferguson dealer has a great overview of the three different transmission types.
   / What tractor to buy for general utility work - <50 Acres?? #24
I like the idea of CVT ... in theory it seems like an awesome idea. However, it doesn't offer any PTO HP benefits is this size, and I don't think I've read anything but negative reviews on those NH CVT models. Lots of electrical gremlins and dissatisfaction with the CVT, from what I've seen anyhow. No real advantage over HST with cruise control.
I have to disagree about the NH CVT. I have a NH CVT and a NH HST. The CVT does not whine, is more responsive to the pedal, and does not work as hard as the HST when using PTO implements. Some of that may be that the Boomer has 40 HP PTO vs 33 HP PTO on the TC40DA. I have not had any problems with my Boomer 8N in the four years since I bought it other than a fender cracked. I have posted good reviews on my tractor, you just may not have seen them. They do both lose about 20% from engine HP to PTO HP which is more than a geared tractor.
   / What tractor to buy for general utility work - <50 Acres?? #25
Dear Luddites,
Where are you getting these clutch replacement prices?
I could replace my clutch, pressure plate, throw out bearing and pilot bearing doing the work myself for around $400.
Though its very doubt full that it will even need it.
I have done many hundreds of tons of loader work and at 1875 hours on my tractor so far I have not needed the first clutch adjustment yet.
   / What tractor to buy for general utility work - <50 Acres?? #26
Gear machines have there place and so does hst. I have driven both. On a garden tractor I prefer hst and like it on my skid steer when doing fine grading and digging. If I am doing field work give me a gear drive tractor. I know allot of people like power shuttle transmissions and the new CVT transmissions. I have seen allot of electronic issues with allot of brands and decided to stick with a gear drive. In my opinion they are simple and reliable if you take care of them. Allot of people ride the clutch and so on. A wet clutch is the way to go with a gear drive but a dry clutch will hold up fine if you take care of them. Most of your semis out there even to this day are gear.
   / What tractor to buy for general utility work - <50 Acres?? #27
Ya know Eric, i'm beginning to think you are not so Oracally. By your standard, anything mechanical can be a "ticking time bomb" which is as ridiculous a statement as one can think of. I'd say you were not a mechanic for very long. On this forum alone, 3 people had trouble with there hydros and were back in the shop for weeks. Not one of these tractors had over 200 hours on them. I'd say by your statements that you are a bit of a control freak and instead of pouting or kicking something when someone doesn't agree with you, you resort to tagging people with names such as "Luddites" as if we were "small minded". The error here of course is your continued attempts to sway people from thinking of a geared tractor as a viable piece of machinery which it certainly is. If 25-35 years of trouble free service from a geared tractor is not long enough to be free from your disparagement, then what is?
   / What tractor to buy for general utility work - <50 Acres?? #28
My first truck went over 200,000 before it needed a clutch, while my last track toy needed a clutch every third weekend. It depends on how you use. Luddites fear industrial change and specifically, technological change. If my intent was to call people pushing back against a CVT or HST transmission, small-minded, I would have selected a different word.
At any-rate, while possible, long intervals between clutch changes are not normative unless the machine is under-utililized in its capacity to work or sits around.
That said, it is easier to use a CVT or HST transmission.
   / What tractor to buy for general utility work - <50 Acres?? #29
Have a MF 135 with 5500 hours and still the first clutch.
   / What tractor to buy for general utility work - <50 Acres?? #30
Both transmission types have there high points. I do prefer gear transmissions on my farm tractors, but that's all we've ever had. In track hoe applications a hydro is something I couldn't live without. But it all comes down to personal preference when a person chooses there machine. The clutch life all comes down to maintenance, my 1952 john deere 60 has NEVER had the clutch replaced. On the other hand it seemed like out high boy 6000 always was getting the clutch replace. But the battle of hydro vs gear all comes down to personal preference
John Deer 3 Point Quick Attach (A59076)
John Deer 3 Point...
2025 YOU-380 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attachments (A59225)
2025 YOU-380 Mini...
2014 Chevrolet Express Van (A55973)
2014 Chevrolet...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A56435)
2017 Yale GLC050VX...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1" Pneumatic Impact Wrench (A59076)
1" Pneumatic...
