What tractor for 3.5 open hilly snowy acres....
   / What tractor for 3.5 open hilly snowy acres.... #1
DCJL
Northern Vermont
New Holland TC34DA
I live in Vermont and need a tractor for the following:
Snowblowing a 700 foot driveway. I've already decided on a front ($) mounted blower.
Grading driveway with a box blade once snow is gone. My driveway is VERY firm with a compressible product like staymat. A York rake doesn't have a chance on it.
Cutting 3.5 acres of open hilly grass. Some spots are VERY steep where the 2 wheel drive garden tractor I currently have can climb up, but would slide down forwards if I went down it. The garden tractor has a 38" deck that I would keep for trimming. For the new tractor I'm thinking 60" deck minimum. Should I go with a RFM or MMM?
I'm also considering (but not necessary) putting a cab on it for those cold Vermont winter snowstorms.
Finally I'll be moving quite a bit of dirt with it, but not really concerned with speed, so I would guess the tractor size may not make much difference.
I've decided on hydro as well as chains for winter. I'm considering anything from a BX2300 to the 33DA. So... thoughts? Thanks
>I've decided on hydro as well as chains for winter. I'm considering anything from a BX2300 to the 33DA. So... thoughts? Thanks<
er... of course I meant the BX2230
So any ideas. I'm thinking of going with the 24DA with 48 months at 0%. Will this be large enough or is the 33DA overkill for 3 acres of lawn?
   / What tractor for 3.5 open hilly snowy acres.... #3
I think a TC24 (if you can find one because they are being replaced by the more expensive TC26) is good for up to about 8 to 10 acres. I wouldn't consider a TC33 under 8 acres unless I was into some major landscape construction projects on the property. The TC24 is not too big for 3.5 acres but I would not want any bigger. Nice thing is it has enough PTO HP to run a fairly large snowblower, (I use a 60" and have never even slowed down my TC24). It runs a nice size mower deck, the FEL is very strong. It is heavy enough for anything but still not too heavy (although it will rut the yard if wet).
Thanks Bob. I was really set on a TC33 but after reading what people had for sized properties, I began to think about it and thought it might be a bit too big for my small acreage. I think you may be right, lets see what others think. The only problem I see is my 13 year old son will probably want some seat time and I probably can't get away with "Its too big for you". /forums/images/graemlins/grin.gif
   / What tractor for 3.5 open hilly snowy acres.... #5
I run a TC18 on 4 acres, Dad has a TC40DA on 30 (10 cleared, rest woods). I'd say the 24 & 33 would both be good choices. for me, the $$$ made the decision easier. The 33 has 3 tranny ranges, and a suspension seat. Both of which are more usefull than you might initially think. You will probably have more room in a cab on the 33.
Kubota has some nice factory cabs, not sure if you can get them on the B series - B2410 or B2910 for example...
   / What tractor for 3.5 open hilly snowy acres.... #6
HELLO DCJL & Welcome Aboard !! You'll love this site.
Well now....TRACTOR size......I love this question. All I can speak of is the experience I have gained out here in the country now for 8 Summers. Hope this is not too long winded. I have 2.3 acres & when I first went looking I was primarily concerned with getting the grass cut. I made a fairly large purhase (for me) on the homestead so I was looking for something around $5K. I ended up getting a 14 HP ACCO Allis with MMM. Also ended up buying a frount mount snowblower early part of first Winter. The Tractor performed admirably for 6 years but at times would get stuck in 4" of snow. Not too often (had chains) but the tractor just wasn't heavy enough. Finally got tired of that & I always wanted to do some landscaping anyways (plus have 2 horses) so wanted something bigger & HEAVIER !! Came very close to buying a Case DX33 new (equivalent to NH TC33D) but was too much cash. Came across a 2001 TC35D with only 79 hours on it. Fell in love with it. The size of this thing just was so much more tractor. The last thing I wanted to do was buy too small & down the road have to go looking again. (Would have kicked myself in the head) As it stands the Class III Boomer was exactly what I needed. Came with a FEL & have used it extensively for moving dirt, clearing snow & of course the non-ending horse manure. With the bigger 6 ft. bucket this made things much easier. Plus, with the added weight (I also added 500 lbs counterweight just this last winter) snow clearing is a slice of cheese. Just to put this in perspective.....I only have turf tires on the tractor. With the added counterweight I did not slip, slide, spin, my tires all winter & we had alot of snow up here in Southern Ontario. For sure I thought when we got into the wet snow in late winter I thought for sure I was going to spin the tires....nothing....absolutely went through the snow like a piece of cake. All summer last year I was thinking of getting chains which I dreaded because they are a pain to put on. Bacame a non-issue. I can probably continue but have already said more than enough. From my experience.....go with the Bx2910 or TC33D. You will not be sorry. You will always get into tasks where a smaller tractor would have been a better fit but having 3.5 acres I feel you need something bigger than a TC24D. Especially with the long drive & the steep hills. The TC33D I feel will be a safer tractor all around.
Good Luck with whatever choice you make. It's an exciting time for you !! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
To all, thanks for the replies, VERY interesting hearing different points of view. I will keep looking for more posts!!! Thanks.
   / What tractor for 3.5 open hilly snowy acres.... #8
I would think that a snowblower would need a good amount of pto power and if your lawn area that you are going to mow is fairly firm then using a 33 would be just the ticket. I also think that having 3 ranges instead of two and having a stronger loader are real pluses and the extra power to box blade your long driveway but if your lawn area is soft then going with a lighter weght tractor would be a better fit for you. When shopping for tractors what have the dealers in your area recommended ?? A good dealer can be very helpful when it comes to these considerations.
Haven't asked any dealers yet. My property is pretty firm, so I think the weight would not be an issue. You are probably correct about the PTO horsepower for the snowblower, plus a wider blower would get the jpb done quicker. OK, so now I'm thinking back to the 33. It would really be a lot nicer for all that dirt I gotta relocate, plus sooner or later I'd like to get a pile of stones to build a stone retaining wall, so the bigger tractor would help.
   / What tractor for 3.5 open hilly snowy acres.... #10
Hello,
We had a 1210 (16-18HP) previous to our TC30 on our small 3 acres and all I can say is that the 1210 worked great and was a little monster but I'am so glad we went bigger. The smaller machine will get the things done for you but with a driveway like that I would suggest a larger machine. It will only make things go quicker and you will feel more secure in the larger of the 2.
Just My 2 Cents
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
48" JOB BOX (A51248)
Roller (A52377)
Roller (A52377)
2025 IR UNUSED Ripper (A53117)
2025 IR UNUSED...
UNUSED HART BRUSHLESS ELECTRIC RIDING MOWER (A51248)
UNUSED HART...
